Forum Topic - trouble detecting mSATA ssd:
I have an Intel NUC D34010WYK and I'm currently booting the generic x86 BSP from a USB flash drive.  The NUC has a mSATA
 SSD and I would like to be able to boot from the SSD instead of the USB flash drive.  If I type 'devb-ahci' I see the
following..
>>devb-ahci
>>Path=0 - AHCI (generic)
(then it hangs.  If I do ctrl-C and type devb-ahci again I get)
>>devb-ahci
>>xpt_configure: ahci SIM attach failure
and it hangs once more, but I can get back to the prompt via ctrl-c.
The SSD is set to AHCI mode in BIOS.
I've tested the board with a 3.5'' SATA hard drive connected to the SATA port and I can detect that hard drive via devb-
ahci.  But I can't detect the mSATA ssd.  Any suggestions are appreciated!
Re: trouble detecting mSATA ssd
Please try the nports option as below:
# devb-ahci ahci nports=6
