Forum Topic - An issue about DMA memory:
hello,
  There is an  issue about DMA memory setting.
  I use mmap() to map a memory and mem_offset() to get the physical address.
  I find that when I use mem_offset() to get the physical address, this function always return Error EOVERFLOW; but when
 I use mem_offset64(),  mostly the physicalAddressA can return the correct value(the value is larger than 2G), and
sometimes it returns value 0 or 1 also. could you tell me why?
this can appear on QNX6.5.0 SP1 system, and the platform is Intel Core i7-3610QE pocessor on x86 with 4G DDR3 RAM. but
if I change the DDR3 RAM to 2G, it is disappear. the mem_offset() can work OK!
the source code is as follow:
        void *virtualAddressA;
	off_t physicalAddressA;
	int   mem_offset_flag = 0;
	int size = 7800;
	virtualAddressA = mmap( 0,
            size,
            PROT_READ|PROT_WRITE|PROT_NOCACHE,
            MAP_PHYS|MAP_ANON,
            NOFD,
            0 );
    if (virtualAddressA == MAP_FAILED) {
          perror("mmap");
          exit(EXIT_FAILURE);
    }else{
	   printf("mmap succeed\n");
//  mem_offset_flag = mem_offset( virtualAddressA, NOFD, size, &physicalAddressA, 0);
    mem_offset_flag = mem_offset64( virtualAddressA, NOFD, size, &physicalAddressA, 0);
    if(mem_offset_flag == -1)
    	printf("mem_offset error: %s!\n",strerror(errno ));
