QNX 6.6 on BeagleBone Black keeps rebooting
08/31/2014 6:16 PM
post111593
this is my first time with QNX on ARM, I have a BeagleBone Black here with QNX 6.6.
QNX boots fine, I even get a shell prompt (I strictly followed "BSP_User_Guide_Texas_Instruments_AM335x_BeagleBone.pdf")
but it keeps rebooting after a few seconds and I have no idea why. Is this normal behaviour? How can I make it stop
rebooting all the time?
Here's what happens:
# ping 192.168.1.2
PING 192.168.1.2 (192.168.1.2): 56 data bytes
64 bytes from 192.168.1.2: icmp_seq=27 ttl=255 time=0 ms
U-Boot SPL 2014.04-00015-gb4422bd (Apr 22 2014 - 13:24:29)
reading args
spl_load_image_fat_os: error reading image args, err - -1
reading u-boot.img
reading u-boot.img
U-Boot 2014.04-00015-gb4422bd (Apr 22 2014 - 13:24:29)
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
*** Warning - readenv() failed, using default environment
Net: <ethaddr> not set. Validating first E-fuse MAC
cpsw, usb_ether
Hit any key to stop autoboot: 0
gpio: pin 53 (gpio 53) value is 1
mmc0 is current device
gpio: pin 54 (gpio 54) value is 1
SD/MMC found on device 0
reading uEnv.txt
81 bytes read in 7 ms (10.7 KiB/s)
gpio: pin 55 (gpio 55) value is 1
Loaded environment from uEnv.txt
Importing environment from mmc ...
Checking if uenvcmd is set ...
gpio: pin 56 (gpio 56) value is 1
Running uenvcmd ...
Device: OMAP SD/MMC
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.4 GiB
Bus Width: 4-bit
reading ifs-ti-am335x-beaglebone.bin
3626804 bytes read in 288 ms (12 MiB/s)
## Starting application at 0x81000000 ...
__________Board ID__________
header: ee3355aa
____________________________
BeagleBone Black detected
VFPv3: fpsid=410330c3
coproc_attach(10): attach fe07a3fc (fe07ad24)
coproc_attach(11): attach fe07a3fc (fe07ad24)
Welcome to QNX Neutrino 6.6.0 on the Texas Instruments AM335x BeagleBone
(ARMv7 Cortex-A8 core) - Board
Starting MMC/SD driver...
starting I2C driver...
starting WDT reset utility...
starting Board ID driver...
Board ID
header: ee3355aa
version: ▒▒▒▒
serial: ▒▒▒▒▒▒▒▒▒▒▒▒
config: ▒▒▒▒▒▒
Setting OS Clock from on-board RTC
Wed Apr 23 20:39:59 GMT 2014
Starting USB OTG Host driver...
Starting SPI driver...
Starting network driver...
starting leds driver...
# Path=0 - TI OMAP3 MMCHS
target=0 lun=0 Direct-Access(0) - SD:3 SU08G Rev: 8.0
