Forum Topic - Syscall to obtain the commandline arguments a process was started with?:
I found devctl calls to obtain information about processes (eg DCMD_PROC_MAPDEBUG_BASE) like process name, thread, mem
and interrupt info. What I'm missing is a possibility to fetch the commandline arguments a process was started with -
like pidin does. (How) can that be done?
Thanks in advance & regards
Thomas
Re: Syscall to obtain the commandline arguments a process was started with?
in QNX 6.6.0 you can read the /proc/<pid>/cmdline
This is a null separated argv list, similar to linux
/proc/<pid>/exefile is also present in 6.6.0
In versions prior to 6.6.0 you would have to do what pidin used to do,
use the debug interface to locate the primary stack, and parse through
the argv, auxv and envp arrays.
On 2014-03-12 12:43 PM, Thomas Klein wrote:
> Thomas
> http://community.qnx.com/sf/go/post109364
> To cancel your subscription to this discussion, please e-mail general-community-unsubscribe@community.qnx.com
RE: Syscall to obtain the commandline arguments a process was started with?
> -----Message d'origine-----
> De : Colin Burgess [mailto:community-noreply@qnx.com]
> Envoyé : 12 mars 2014 14:30
> À : general-community@community.qnx.com
> Objet : Re: Syscall to obtain the commandline arguments a process was started
> with?
Couldn't find any reference to this in the doc ( Steve are you reading this)
ls -l /proc/<pid> only shows as
ls /proc/<pid> shows as, cmdline and execfile as expected
cat /proc/<pid>/cmdline
/proc/<pid>/cmdline: No such process
Is that expected?
> In versions prior to 6.6.0 you would have to do what pidin used to do, use the
> debug interface to locate the primary stack, and parse through the argv, auxv
> and envp arrays.
> Is that expected?
You probably did something wrong.
# pidin -p 28687 arg
      pid Arguments
    28687 io-pkt-v6-hc -dsmsc9500 mac=96a414016206
# echo `cat /proc/28687/cmdline`
io-pkt-v6-hc-dsmsc9500mac=96a414016206
> De : Aleksandar Ristovski [mailto:community-noreply@qnx.com]
> Envoyé : 12 mars 2014 15:12
> with?
> > this)
> > Is that expected?
Almost, against increment odd I ended using a pid of a zombie process!!!!
>       pid Arguments
>     28687 io-pkt-v6-hc -dsmsc9500 mac=96a414016206 # echo `cat
> http://community.qnx.com/sf/go/post109368
Re: RE: Syscall to obtain the commandline arguments a process was started with?
Yes, I've already noted this as something to add to the docs.
Thanks for your reply, Colin. I'm working wit 6.50SP1, so I'll have to use the pidin way to do it. Can you point to any
piece of information explaining a little bit more detailed how to do it?! I'm not yet familiar with using "the debug
interface to locate the primary stack, and parse through  the argv, auxv and envp arrays".
