Forum Topic - application profiling doesn't display call count:
Hi-
The application profiler doesn't show call count information in the Execution Time view inside Momentics (see attached
screenshot).  Here are the steps I've taken, can you please tell me where I've gone wrong, or what I've missed?
I'm compiling using a Makefile using the -g -p switches.  I refresh the IDE so it knows about the new binary files.  I
right-click on the debug binary and select Profile As-->Profile Configurations.  I create a new profile under C/C++ QNX
Attach to Remote Process via QCONN (IP).  I'm connecting to my target on port 8000.  Inside the tools menu, I've added
the Application Profiler and selected Sampling and Call Count Instrumentation.
I've tried setting the QCONN_PROFILER to /dev/profiler as suggested here:
http://www.qnx.com/developers/docs/6.5.0/index.jsp?topic=%2Fcom.qnx.doc.ide.userguide%2Ftopic%
2Fprofiler_profile_already_running_.html
I'm using Momentics IDE version 4.7.0, running QNX version 6.5.0SP1.
Any suggestions or tips would be greatly appreciated.
Alex
Attachment: Image ExecutionTimeWindow.png 67.51 KB
Re: application profiling doesn't display call count
Hi Alex,
I'm facing exactly the same problem. Have you managed to find out why it doesn't work?
Andrey
Please anyone...
Hi Andrey-
Sorry, I was unable to figure out the tool issue.  I solved my problem through other means.
-Alex
Thanks!
