Forum Topic - SIGSEGV issues with aio functions: (2 Items)
The overly simplistic description of what I am experiencing is a SIGSEGV error within an aio thread.  See the attachment
This is what we know:
1)	It only happens after executing aio_read.  Occasionally we also get this error within a devctrl thread.
2)	I have never observed this after executing an aio_write.
3)	We experience this issue when using a callback method with the aio_sigevent
Here’s the cleaned version of this code:  Note that this code is called simultaneously from 3 threads within our
application for 3 different UARTS.
static void _Hal_DataRxd (union sigval val);
  OS_SemPost((tOS_SEMAPHORE)val.sival_int);
tINT16 Hal_UartGetBlock(tHAL_UART_PORT Port, tUINT8* pData, tINT16 SizeOfRequest)
  tUart *pUart;                                 // Pointer to our UART control structure.
  struct aiocb Async;                           // Asynchronous control block for the UART.
  const struct aiocb *pList[1] = { &(Async) };  // List of our asynchronous control blocks.
  struct timespec Timeout;                      // Interval timeout to wait for asynchronous transfer.
  int Retry;                                    // TODO: comment
  int Result;                                   // The resulting exit code of system calls.
  ssize_t Count;                                // The number of bytes read from the driver.
  tERROR Error;
  // Validate our arguments.
  if (Port >= dHAL_INFO_UART_TOTAL)
    { return (dEOF); }
  if (pData == dNULL)
    { return (dEOF); }
  if (MaxSize <= 0)
    { return (dEOF); }
  pUart = &(Uarts[Port]); // Grab the requested UART.
  // Check that the port is not already opened.
  if (pUart->Fd == -1)
    { return (dEOF); }
  // Setup our asynchronous control block for the UART.
  Async.aio_fildes = pUart->Fd;
  Async.aio_buf = (volatile void *)pData;
  Async.aio_nbytes = SizeOfRequest;
  Async.aio_offset = 0;
  Async.aio_reqprio = 0;
  Async.aio_lio_opcode = LIO_NOP;
 SIGEV_THREAD_INIT(&(Async.aio_sigevent), &_Hal_DataRxd, pUart->pSem, NULL );
 // Queue the asynchronous read.
  Result = aio_read((void*)&(Async));
  if (Result < 0)
    aio_error(&(Async));
    return (dEOF);
  Error = OS_SemPend(pUart->pSem, 30);
  if(Error != dOS_ERROR_NONE)
    return(0);
  // Get the asynchronous transfer byte count.
  Count = aio_return((void*)&(Async));
  if (Count < 0)
    { Count = 0; }
  return (Count);
We also see another issue when NOT using the callback method.
Here we use the aio_suspend.  We implemented a do-while loop because we get an error code of 236 returned from the
aio_suspend function (system resource busy).  It usually takes multiple retries before the system resource is no longer
busy.
Occasionally, it is busy indefinitely (loop increased to 1 billion).  We’ve added usleeps of ~2ms before the
aio_suspend in this code and it tends to relieve some of the retries but not all.
Besides and error 236 from aio_suspend we occasionally get a SIGSEGV type errors here too like the above callback method
 SIGEV_NONE_INIT(&(Async.aio_sigevent));
  if (Result < 0)
    return (dEOF);
  // Determine the relative timeout delay to wait.
  Timeout.tv_sec = 0;
  Timeout.tv_nsec = (30 * 1000000);
 Retry = 0;
  do
    Retry++;
    Result = aio_suspend(pList, 1, &Timeout);
    if (Result < 0)
      Result = aio_error(&(Async));
      if (Result == dOS_EAGAIN)
        break;
  } while ((Result != dOS_EOK) && (Retry < 10));
Attachment: Image AioSigError.jpg 500.57 KB
Re: SIGSEGV issues with aio functions
This is with an TI AM335x based BSP.
