Trackers
Trackers
Forum Topic - Linking GLES2 programs...: (4 Items)
I have some projects that use GLES2 and I keep getting
"unknown symbol: _gles1_cm_fntbl"
"unknown symbol: _gles1_fntbl"
"unknown symbol: _gles2_fntbl"
which I guess are all defined in libEGL.so..
but 'ldd ../lib/libbag.video.puregl.so' doesn't complain....
Hmm... maybe it's because I'm using RTLD_LOCAL ? hmm no
Any hints would be appreciated.
Attachment: Image lddsuccess.png 145.01 KB
Re: Linking GLES2 programs...
It is not clear from your post what is your code doing. I am assuming it
is dlopening libbag.video.pureg.so.
If so, it is sufficient that you pass '0' as RTLD flags (unless you have
specific goals).
To make sure everything resolves correctly: when running ldd (or your
program), specify LD_BIND_NOW=1
e.g.:
# LD_BIND_NOW=1 ldd ../lib/libbag.video.puregl.so
Aleksandar
> http://community.qnx.com/sf/go/post103657
> To cancel your subscription to this discussion, please e-mail general-community-unsubscribe@community.qnx.com
> specific goals).
I did this, the output is the same as without the LD_BIND_NOW=1
> e.g.:
> Aleksandar
> > General
got around manually loading libEGL.so before loading the libraries that link to GLES. (manual meaning I used dlopen)
