Using two network cards with QNX 6.2.1
05/17/2013 5:23 AM
post101508
I have a embedded system (PC/104+ based) running on QNX 6.2.1 which has a Ethernet adapter (AMD PCNET (AMD-79c97x)), and
the QNX boot script looks like
io-net -d pcnet transmit=64,reveive=32,verbose=2 -p tcpip &
waitfor /dev/socket
this works fine.
Now I need to expand the function of this embedded system by adding another Ethernet adapter. I have added a PC/104+
Ethernet module (http://www.dpie.com/pc104/mercator.html) and made the following change to the QNX boot script
waitfor /dev/socket
mount -T io-net devn-ns83815.so
waitfor /dev/socket 5
clearly this doesn't work. I have the following message on the terminal
mount: Can't mount / (type io-net)
mount: Possible reason: No such device
Any help will be appreciated.
Thanushan
Re: Using two network cards with QNX 6.2.1
05/17/2013 7:44 AM
post101511
If you run the commands below manually, does it work? If not, please post
the output of 'pci -v'.
Also, your waitfor commands should wait for the specific interface to
become active. e.g. 'waitfor /dev/io-net/en0'
On 2013-05-17 5:23 AM, "Thanushan Balakrishnan"
<community-noreply@qnx.com> wrote:
>Hi,
>Ethernet adapter (AMD PCNET (AMD-79c97x)), and the QNX boot script looks
>like
>waitfor /dev/socket
>this works fine.
>another Ethernet adapter. I have added a PC/104+ Ethernet module
>waitfor /dev/socket
>Thanks
>Thanushan
>General
>http://community.qnx.com/sf/go/post101508
>general-community-unsubscribe@community.qnx.com
05/20/2013 4:17 AM
post101552
works. But the second card is not detected.
I've added 'pci -v' to the bootscript after the
pci-bios &
waitfor /dev/pci
but I don't see anything different.
Thanks for your help
Thanushan
05/21/2013 5:45 AM
post101564
I've run the pci -v. The new card is not showing up.
I think, the new card is not on the PCI bus. I'm bit confused because the new board sits between the CPU module and the
existing board, and the existing board is still working!
Any help will be appreciated,
Thanushan
05/27/2013 7:49 AM
post101711
If the device doesn't show up with the pci utility, then there is some
electrical problem.
On 2013-05-21 5:45 AM, "Thanushan Balakrishnan"
>Hi,
>new board sits between the CPU module and the existing board, and the
>Thanks,
>Thanushan
>General
>http://community.qnx.com/sf/go/post101564
05/29/2013 6:14 AM
post101801
Hi Hugh,
Your were right. Changing the motherboard to a newer version makes the new card to appear on the PCI bus.
what should I do to QNX to make the driver functioning?
I've tried the following but it didn't work
io-net -d pcnet transmit=64,receive=32,verbose=2 -p tcpip &
waitfor /dev/socket
waitfor /dev/io-net/en1 5
any suggestion?
Thanushan
05/29/2013 7:40 AM
post101806
Are there any error messages in the sloginfo output?
You can also change the 'waitfor /dev/socket' to 'waitfor /dev/io-net/en0'.
On 2013-05-29 6:14 AM, "Thanushan Balakrishnan"
>Hi Hugh,
>waitfor /dev/socket
>any suggestion?
>Thanks,
>Thanushan
>General
>http://community.qnx.com/sf/go/post101801
05/29/2013 9:25 AM
post101811
I've done the following
io-net -d pcnet transmit=64,receive=32,verbose=2 -d ns83815 vid=0x100,did=0x20 -p tcpip &
waitfor /dev/socket 8
then used the ifconfig utility to configure the IP address for en1
ifconfig en1 10.0.0.3
When I run the "natstat -in" i'm seeing the following
Name Mtu Network Address Ipkts Ierrs Opkts Oerrs Colls
lo0 33212 <Link>
0 0 0 0 0
lo0 33212 127 127.0.0.1 0 0 0 0 0
en0 1500 <Link> 00:05:e5:00:19:9d 3448 0 3465 0 0
en0 1500 10 10.0.0.2 3448 0 3465 0 0
en1 1500 <Link> 00:06:d5:20:63:33 129 0 15 0 0
en1 1500 10 10.0.0.3 129 0 15 0 0
The Ethernet port (en0) is connected to a PC, when I run "ping 10.0.0.3" from the PC, its not getting any response.
Do I need to configure anything else?
Thanushan
05/29/2013 9:28 AM
post101812
You cannot have 2 interfaces on the same subnet, so you will have to use a
different subnet for en1 or setup routing tables.
On 2013-05-29 9:25 AM, "Thanushan Balakrishnan"
>Hi,
>Colls
>lo0 33212 <Link> 0 0 0 0
> 0
> 0
> 0
> 0
> 0
> 0
>Thanks,
>Thanushan
>General
>http://community.qnx.com/sf/go/post101811
05/29/2013 10:46 AM
post101818
Hi Hugh,
How do I set different subnet? sorry, this must be very basic, but this is all new to me.
could you give an example?
Thanushan
05/29/2013 10:54 AM
post101819
It all depends on your netmask. The default netmask is 0xfffff000, which
you can see with ifconfig. So, to change to a different subnet when your
first IP address is on 10.0.0.X, another subnet would be on address
10.1.0.X or 10.0.241.X.
On 2013-05-29 10:46 AM, "Thanushan Balakrishnan"
>Hi Hugh,
>is all new to me.
>Thanks,
>Thanushan
>General
>http://community.qnx.com/sf/go/post101818
05/30/2013 5:39 AM
post101861
I've changed the ip address, here is the ifconfig
en0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
address: 00:05:e5:00:19:9d
media: Ethernet 100baseTX full-duplex
status: active
inet 10.0.0.2 netmask 0xfffff000 broadcast 10.0.15.255
en1: flags=8c43<UP,BROADCAST,RUNNING,OACTIVE,SIMPLEX,MULTICAST> mtu 1500
address: 00:06:d5:20:63:33
status: active
inet 10.1.0.3 netmask 0xfffff000 broadcast 10.1.15.255
still unable to ping 10.1.0.3.
on the above ifconfig output for en1 is "OACTIVE", what does it mean?
Thanushan
05/30/2013 8:06 AM
post101869
Is the 10.1.0.3 connection also connected to the same network as the
10.0.0.2? If so, this will not work. You have to have the 10.1.0.3
interface connected on a separate network to another machine that is also
on the 10.1.x.x network.
On 2013-05-30 5:39 AM, "Thanushan Balakrishnan"
> status: active
> status: active
>Thanks,
>Thanushan
>General
>http://community.qnx.com/sf/go/post101861
05/30/2013 8:43 AM
post101873
Hi Hugh,
The 10.0.0.2 and 10.1.0.3 are connected to different machines.
The 10.0.0.2 was connected to a machine with ipaddress 10.0.0.1, subnetmask 255.0.0.0
The 10.1.0.3 was connected to a machine with ipadderss 10.1.0.2, subnetmask 255.255.240.0
This failed on ping test.
now I've changed to
The 10.0.0.2 is connected to a machine with ipaddress 10.0.0.1, subnetmask 255.255.240.0
The 10.1.0.3 is connected to a machine with ipadderss 10.1.0.2, subnetmask 255.255.240.0
this has some success. When I ping the 10.1.0.3 from 10.1.0.2, response 1 out of 4 to 3 out of 4 received (25% to 75%
success).
I guess, Intermittent failures means something wrong in the hardware?
Thanushan
05/30/2013 10:05 AM
post101881
This could be due to an interrupt issue. Yes, check the hardware.
On 2013-05-30 8:43 AM, "Thanushan Balakrishnan"
>Hi Hugh,
>now I've changed to
>out of 4 to 3 out of 4 received (25% to 75% success).
>Thanks,
>Thanushan
>General
>http://community.qnx.com/sf/go/post101873
06/03/2013 9:58 AM
post101982
Hi Hugh,
I start to think it's not a hardware issue. I did a simple test by ping the Network card (ip address 10.1.0.3) from the
PC (ip address 10.1.0.2) while a Ethernet protocol analyzer software running on the PC (Ethereal). The software reports
that the 10.1.0.3 did not reply to some of the pings.
However, when I ping the PC from QNX (ip address 10.1.0.3) the Ethereal shows that the PC receives all the pings and
responds to it. This implies the Network card or QNX driver not getting the received packets.
When I run the ifconfig, I see the following
lo0: flags=8009<UP,LOOPBACK,MULTICAST> mtu 33212
capabilities=7<IP4CSUM,TCP4CSUM,UDP4CSUM>
enabled=0<>
status: active
inet 10.0.0.2 netmask 0xff000000 broadcast 10.255.255.255
status: active
What does the OACTIVE flag on en1 means?
Thanushan
06/03/2013 10:53 AM
post101985
The OACTIVE flag means that the driver is either busy transmitting or that
the driver doesn't have any transmit space left. The fact that the driver
is seeing all the packets from the QNX machine, tells me that the driver
is working. Why it doesn't see all the packets from the other machine, I'm
not sure. Both of these drivers have been working for years.
On 2013-06-03 9:58 AM, "Thanushan Balakrishnan"
>Hi Hugh,
>the Network card (ip address 10.1.0.3) from the PC (ip address 10.1.0.2)
>The software reports that the 10.1.0.3 did not reply to some of the pings.
>shows that the PC receives all the pings and responds to it. This implies
> enabled=0<>
> status: active
> status: active
>Thanushan
>General
>http://community.qnx.com/sf/go/post101982
06/04/2013 3:37 AM
post101992
Hi Hugh,
I found this article on QNX website
http://www.qnx.org.uk/developers/docs/6.3.2/neutrino/technotes/finetune_net.html
which lists "National Semiconductor ne83815" as a low-performance NIC. I could not find a ne83815 anywhere (on the web
or from National Semiconductor), does this actually means ns83815? this is the one I'm using. If so, may be the problem
I'm facing is down to the fact that the NIC is a low-performance one.
Thanushan
06/04/2013 7:18 AM
post101996
Yes, it is a low performance ns83815, but it should still work. You should
be able to run a 'ping -fs2048 io.address' to the machine with the ns83815
without losing any packets. That is a typo on our web site - it should
read ns83815.
On 2013-06-04 3:37 AM, "Thanushan Balakrishnan"
>Hi Hugh,
>t.html
>could not find a ne83815 anywhere (on the web or from National
>using. If so, may be the problem I'm facing is down to the fact that the
>Thanks,
>Thanushan
>General
>http://community.qnx.com/sf/go/post101992
06/04/2013 8:16 AM
post101998
Mmm
tried 'ping -fs2048 10.1.0.3' still same issue. Intermittent time out!
Thanks for the info
Thanushan
06/05/2013 10:12 AM
post102018
By switching the network card on the PC end made the 'ping' command 100% successful.
Thanushan
06/05/2013 10:25 AM
post102019
Thanks for letting me know.
On 2013-06-05 10:12 AM, "Thanushan Balakrishnan"
>successful.
>Thanushan
>General
>http://community.qnx.com/sf/go/post102018
06/06/2013 5:52 AM
post102038
How can I make my QNX machine as a router?
My QNX machine has two NICs, en0 and en1.
en0 associated with IP address 10.0.0.2, subnetmask 255.255.240.0 and connected to 10.0.0.1
en1 is associated with IP address 10.1.0.3, subnetmask 255.255.240.0 and connected to 10.1.0.4
I believe it is possible for 10.1.0.4 to ping 10.0.0.1 (routing through QNX machine).
When I run the 'route show' command, I get the following output
Routing tables
Internet:
Destination Gateway Flags
default link#2 U
10.0.0.0 link#2 U
10.0.0.1 0:17:3f:cf:3:95 UH
10.1.0.0 link#3 U
10.1.0.4 2c:27:d7:26:fd:91 UH
127.0.0.1 127.0.0.1 UH
I tried to 'ping 10.0.0.1' from 10.1.0.4, but that failed.
So, I did
route add -net 10.0 -interface 10.0.0.2
route add -net 10.1 -interface 10.1.0.3
but that didn't make any difference.
I don't know what I'm doing wrong, Can you help?
Thanushan
05/18/2013 3:36 PM
post101549
Below is an extract from my "/etc/system/sysinit" on QNX 6.3.0 :
# Note : Start the protocol stack for LAN B before LAN A since the rtl8169
# driver seems to 'grab' both interfaces even though pci=0 is specified.
# This approach works, but the second io-net command generates an error
# message.
io-net -i 1 -d rtl8169 pci=1,duplex=1,speed=100 -p tcpip prefix=/lanb
waitfor /lanb/dev/socket
SOCK=/lanb ifconfig en0 test_rtu_b netmask 255.255.255.0
SOCK=/lanb route add -net default router_b
SOCK=/lanb inetd &
io-net -d rtl8169 pci=0,duplex=1,speed=100 -d i82544
vid=0x8086,did=0x107C -p tcpip
waitfor /dev/socket
ifconfig en0 test_rtu_a netmask 255.255.255.0
route add -net default router_a
inetd &
hostname test_rtu_a
Here, I am using two similar network cards and the scripts allows me to
configure each one. I hope this helps somewhat.
Nonso Anyaegbunam
> Thanushan Balakrishnan <mailto:community-noreply@qnx.com>
> 17 May 2013 10:23 AM
> has a Ethernet adapter (AMD PCNET (AMD-79c97x)), and the QNX boot
> script looks like
> waitfor /dev/socket
> this works fine.
> waitfor /dev/socket
> Thanks
> Thanushan
05/20/2013 4:24 AM
post101553
Thanks for the response.
io-net -i 1 -d ns83815 pci=1 -p tcpip prefix=/lanb
SOCK=/lanb inetd &
waitfor /dev/socket
which didn't make any different.
In your script the rtl8169 is used twice, once in
'io-net -i 1 -d rtl8169 pci=1,duplex=1,speed=100 -p tcpip prefix=/lanb'
and again in
'io-net -d rtl8169 pci=0,duplex=1,speed=100 -d i82544 vid=0x8086,did=0x107C -p tcpip'
do you have two rtl8169 and a i82544?
Thanushan
05/20/2013 8:32 AM
post101558
Hi Thanushan,
Yes, my system has 3 network cards: 2x rtl8169 and 1x i82544.
Nonso
From: Thanushan Balakrishnan <community-noreply@qnx.com>
To: general-community <general-community@community.qnx.com>
Sent: Monday, 20 May 2013, 9:24
Subject: Re: Using two network cards with QNX 6.2.1
SOCK=/lanb inetd &
waitfor /dev/socket
and again in
Thanushan
General
http://community.qnx.com/sf/go/post101553
To cancel your subscription to this discussion, please e-mail general-community-unsubscribe@community.qnx.com
05/30/2013 5:51 AM
post101862
Hi Nonso,
You have configured one rtl8169 and a i82544 on the same tcpip stack. So, I assume rtl8169 will be en0 and i82544 will
be en1, is that right?
But only assigned ipaddress for en0.
I've got my system to detect the two network adapters by trying similar to yours. I've given IP address for both but I
can not ping the en1.
Thanushan
