Forum Topic - PCI express: (6 Items)
PCI express
From  AIMB580(Advantech Intel Mother Board) I am connecting PCIe to Master
FPGA card(Xilinx).
When QNX system is booting up at that time PCIe detecting Master FPGA card
with status as Address locations are enabled.
When I power off Master FPGA card at that time pcie is not detecting.
When I power ON again Master FPGA card PCIe was detecting but all Memory
locations are disabled & Interrupt line also no connection.
Now I want solution for
Even when I Power off or Power ON for Master FPGA at that time also PCIe
should detect with memory locations status as enabled.
Please send me solution as early as possible.
Thanks & Regards
  Srilakshmi
Attachment: HTML sf-attachment-mime6171 2.74 KB
Re: PCI express
You will have to use the pci_rescan_bus() function after you have powered the FPGA card to re-assign the memory and
interrupts. There is no automatic detection after the PCI server has been started.
From: srilakshmi <community-noreply@qnx.com<mailto:community-noreply@qnx.com>>;
Reply-To: "general-community@community.qnx.com<mailto:general-community@community.qnx.com>;" <general-community@
community.qnx.com<mailto:general-community@community.qnx.com>>;
Date: Friday, 19 October, 2012 3:38 PM
To: "general-community@community.qnx.com<mailto:general-community@community.qnx.com>;" <general-community@community.
Subject: PCI express
From  AIMB580(Advantech Intel Mother Board) I am connecting PCIe to Master FPGA card(Xilinx).
When QNX system is booting up at that time PCIe detecting Master FPGA card with status as Address locations are enabled.
When I power ON again Master FPGA card PCIe was detecting but all Memory locations are disabled & Interrupt line also no
 connection.
Even when I Power off or Power ON for Master FPGA at that time also PCIe should detect with memory locations status as
enabled.
Thanks & Regards
  Srilakshmi
Attachment: HTML sf-attachment-mime6180 4.46 KB
RE: PCI express
I tried using PCI_RESCAN_BUS() function to detect the PCI, it says pci
detected. BUt i have intr line vlaue getting changed.On intial start up
value i got was 10 but latter when FPGA is switched ON&OFF the value is
getting, 6 as per documnet 6 represent the floppy drive
ON reading info it gives information but codes behave improperly when we
send data to the PCI
card
DOcument say it is used in HOT SWAP condition,Is this hot swap automatic,as
we are not using any
QNX function for hot swap in our code.
From: Hugh Brown [mailto:community-noreply@qnx.com]
Sent: Friday, October 19, 2012 4:51 AM
To: general-community@community.qnx.com
Subject: Re: PCI express
the FPGA card to re-assign the memory and interrupts. There is no automatic
Reply-To: "general-community@community.qnx.com"
<general-community@community.qnx.com>
FPGA card(Xilinx).
Thanks & Regards
  Srilakshmi
Attachment: HTML sf-attachment-mime6226 6.9 KB
Re: PCI express
We don't support hot swap in the PCI server, so you will have to remember the interrupt that you first got and use this
same interrupt on subsequent power down/up events.
Date: Saturday, 20 October, 2012 1:10 PM
Cc: "amitn@vrindatech.com<mailto:amitn@vrindatech.com>;" <amitn@vrindatech.com<mailto:amitn@vrindatech.com>>;
Subject: RE: PCI express
I tried using PCI_RESCAN_BUS() function to detect the PCI, it says pci detected. BUt i have intr line vlaue getting
changed.On intial start up value i got was 10 but latter when FPGA is switched ON&OFF the value is getting, 6 as per documnet 6 represent the floppy drive
ON reading info it gives information but codes behave improperly when we send data to the PCI
card
DOcument say it is used in HOT SWAP condition,Is this hot swap automatic,as we are not using any
To: general-community@community.qnx.com<mailto:general-community@community.qnx
.com>;
 connection.
enabled.
Thanks & Regards
  Srilakshmi
Attachment: HTML sf-attachment-mime6247 8.95 KB
RE: PCI express
   I wanted to receive data from windows systems through LAN cable.
Like in windows we are monitoring through Ethereal or wire shark like that
for qnx is there any settings?
To see what ever receiving data through LAN cable.
Thanks & Regards
  Srilakshmi
Sent: Monday, October 22, 2012 4:26 AM
the interrupt that you first got and use this same interrupt on subsequent
Cc: "amitn@vrindatech.com" <amitn@vrindatech.com>
card
FPGA card(Xilinx).
Thanks & Regards
  Srilakshmi
Attachment: HTML sf-attachment-mime6896 10.81 KB
Re: PCI express
You can use the tcpdump utility.
Date: Thursday, 8 November, 2012 7:53 PM
Like in windows we are monitoring through Ethereal or wire shark like that for qnx is there any settings?
Thanks & Regards
  Srilakshmi
To: general-community@community.qnx.com<mailto:general-community@community.qnx.com>;
card
.com>;
 connection.
enabled.
Please send me solution as early as...
Attachment: HTML sf-attachment-mime6902 12.55 KB
