Re: egalax touchscreen on panda board
10/24/2012 9:53 AM
post96592
Hi Eric,
thank you for your answer
Actually I got no calib.(hostname), so I created a fictive one (hope it is the proper format) with default value
# cat /etc/system/config/calib.EA0073
0x0:-1x-1:10 10 FFF FFF 0
I launched hid driver
# io-hid -degalax
I could see eGalax and event when I touched the screen
# hidview -a
HIDD v1.00, v1.00 DDK
Device Address : 0
Vendor : 0x0eef (eGalax Inc.)
Product : 0x0001 (USB TouchController)
Version : r1.10
Usage : Pointer
Report Data :
00 :
00 : 81 90 03 51 02
00 : 81 8d 03 51 02
I tried to attach it to devi drivers and it failed
# devi-hid -Prvvvvvv touch
Looking up touch in module table
Calibration filename: /etc/system/config/calib.EA0073
Resetting module touch
Resetting module abs
Did not find calib info for [639x479]. Attempting to use calculated transformation.
Calibration Matrix An: 0, Bn: 0, Cn: 0, Dn: 0, En: 0, Fn: 0, Divider: 0
InpDuetv:i cset airntsienrgt inoonn: Pdheovtiocne iinntsetrafnaccee
= 1270d0, device no = 0
interrogate bus, returning abs
Attached touch screen report
gf_dev_attach(): error = 2
Process 122900 (devi-hid) terminated SIGSEGV code=1 fltno=11 ip=78008428(/proc/boot/libgf.so.1@gf_display_attach+0x18)
ma
paddr=00008428. ref=00000000
I got the same error with usb driver.
Best Regards
