Forum Topic - Security policy compliant:
I am a security personnel working in a secured environment. There have been many suggestions on the use of QNX on thin
clients. I have little info on QNX.
I would like to know if QNX can comply to all our security policies. I am not able to list all policies' items here.
However, some of which are:
- Maximum and Minimum password age.
- built-in administrator account must be renamed.
- account must expire in 90 days.
- two-factor authentication for remote administration
- password must meet complexity requirements
- ftp, dhcp, dns, telnet, qdaemon, lpd, CDE, NFS, must be disabled
- account lock out threshold
- user must change password at next logon
- account lockout duration
- minimum number of weeks before a password can be reset
- the number of days before a system issues a warning that a password change is required
RE: Security policy compliant
Who told you that?
> -----Message d'origine-----
> De : Hii Sing Chung [mailto:community-noreply@qnx.com]
> Envoyé : 24 août 2012 11:25
> À : general-community
> Objet : Security policy compliant
> many suggestions on the use of QNX on thin clients. I have little info on QNX.
> able to list all policies' items here. However, some of which are:
> change is required
> http://community.qnx.com/sf/go/post95119
> To cancel your subscription to this discussion, please e-mail general-
> community-unsubscribe@community.qnx.com
I don't know what you are referring to. I just want to know if QNX can be securely hardened like that of Windows or
Linux.
I have never worked with a QNX but I did ask the developers if a set of security policies can be applied to them and
they told me cannot (because QNX is embedded system). So, I want to confirm that.
If it cannot comply to security policy, then such devices shouldn't be on our network.
> Envoyé : 24 août 2012 19:58
> securely hardened like that of Windows or Linux.
> security policies can be applied to them and they told me cannot (because
It's confirmed ;-)
> network.
> http://community.qnx.com/sf/go/post95136
Re: Security policy compliant
I am not sure if your company is developing the QNX-based device? If the project is large enough, it may be worthwhile
discussing possible options.
QNX is based on a Microkernel. All the stuff you mention below are not part of the kernel. They are implemented as
standard processes, and as such, can be modified or extended to match your required behaviour. QNX has a Custom
Engineering department that possibly could do this.
> is required
