Forum Topic - PCIe :
PCIe
  How to know PCIe chip has DMA interface or not?
i got DMA channels but how to use them is i am not getting in APIs.
Do you have any sample code or document regarding this?
if you have please send it to me.
Thanks & Regards
 Srilakshmi
Re: PCIe
community-noreply@qnx.com wrote:
If you want to work with a PCIe chip at register level you must have the
hardware spec of that chip.
The location and design of the DMA registers are chip specific ... and
no API will handle it.
  Please ask the vendor of the board for the documentation.
Did you already a search for a LINUX driver ??
--Armin
> Thanks & Regards
>   Srilakshmi
> http://community.qnx.com/sf/go/post94256
> To cancel your subscription to this discussion, please e-mail general-community-unsubscribe@community.qnx.com
RE: PCIe
I want your help in using DMA channels ,DMA register ....
I need DMA stuff...
Do u provide me any documents regarding DMA?
Thanks & Regards
 Srilakshmi
From: Armin Steinhoff [mailto:community-noreply@qnx.com]
Sent: Saturday, July 14, 2012 3:15 AM
To: general-community@community.qnx.com
Cc: community-noreply@qnx.com; community-noreply@qnx.com
Subject: Re: PCIe
--Armin
> Thanks & Regards
>   Srilakshmi
General
http://community.qnx.com/sf/go/post94258
RE: PCIe
DMA is implemented by the device itself. Take for example a sound card, if it needs to play sound you would set some
register in the card telling it at what adresse the sound data is and how big the block is. Then you would write into a
register to tell it to start the transfer. For recording sound, you would write into some of the sound card's register
where to write the data and how much data it is allow to write. In both cases, typically when the transfer is complete
an interrupt is generated to inform the processor so the program can take what ever action is required.
There is no standard or documentation on DMA, and every device is different. You need to learn about the particular of
the hardware you are using. DMA is not a function of the CPU or Chips et or motherboard. It a feature implemented in the
 device.
______________________________________
Sent: Friday, July 20, 2012 2:18 PM
Subject: RE: PCIe
I need DMA stuff...
Thanks & Regards
 Srilakshmi
Subject: Re: PCIe
--Armin
> Thanks & Regards
>   Srilakshmi
General
General
http://community.qnx.com/sf/go/post94360
Re: PCIe
srilakshmi,
you can post this 10 times more  ... it will not change the realty :)
--Armin
> I need DMA stuff...
> Thanks & Regards
>   Srilakshmi
> Subject: Re: PCIe
>> Hi,
> --Armin
>> Thanks & Regards
>>    Srilakshmi
>> General
RE: PCIe
Is any driver required for accessing DMA Registers?
Thanks & Regards
 Srilakshmi
Sent: Friday, July 20, 2012 12:52 AM
Cc: srilakshmi; srilakshmi
Subject: Re: PCIe
srilakshmi,
--Armin
> I need DMA stuff...
> Thanks & Regards
>   Srilakshmi
> Subject: Re: PCIe
>> Hi,
> --Armin
>> Thanks & Regards
>>    Srilakshmi
>> General
General
http://community.qnx.com/sf/go/post94362
RE: PCIe
> -----Message d'origine-----
> De : srilakshmi [mailto:community-noreply@qnx.com]
> Envoyé : 20 juillet 2012 17:06
> À : general-community@community.qnx.com
> Objet : RE: PCIe
No, just need the usual mmap_device_io or mmap_device_memory.
> Thanks & Regards
>  Srilakshmi
> Subject: Re: PCIe
> srilakshmi,
> --Armin
> > I need DMA stuff...
> > Thanks & Regards
> >   Srilakshmi
> > Subject: Re: PCIe
> >> Hi,
> > the hardware spec of that chip.
> > --Armin
> >> Thanks & Regards
> >>    Srilakshmi
> >> General
> > General
> > General
> http://community.qnx.com/sf/go/post94363
RE: PCIe
Is it possible to run .exe file in qnx??
If possible give me the information how to run .exe file on qnx???
My .exe file is .ru.exe
I have tried like this ./ru,  ./ru.exe
I am getting syntax error..
Thanks & Regards
  srilakshmi
Subject: Re: PCIe
srilakshmi,
--Armin
> I need DMA stuff...
> Thanks & Regards
>   Srilakshmi
> Subject: Re: PCIe
>> Hi,
> --Armin
>> Thanks & Regards
>>    Srilakshmi
>> General
General
Re: PCIe
No, you cannot run a .exe file under QNX.
Sent from Blackberry
----- Original Message -----
From: srilakshmi [mailto:community-noreply@qnx.com]
Sent: Tuesday, July 24, 2012 02:33 PM
To: general-community@community.qnx.com <general-community@community.qnx.com>
Subject: RE: PCIe
Thanks & Regards
  srilakshmi
Subject: Re: PCIe
srilakshmi,
--Armin
> I need DMA stuff...
> Thanks & Regards
>   Srilakshmi
> Subject: Re: PCIe
>> Hi,
> --Armin
>> Thanks & Regards
>>    Srilakshmi
>> General
General
General
http://community.qnx.com/sf/go/post94385
RE: PCIe
a) Is Perl present in QNX Target ?
b) What is the command for "nm" for QNX ? Like qcc-nm or qccnm
c) Check what is the command for qcc when executed on windows machine.
Thanks & Regards
  Srilakshmi
From: Hugh Brown [mailto:community-noreply@qnx.com]
Sent: Tuesday, July 24, 2012 4:28 AM
To: 'general-community@community.qnx.com'
Subject: Re: PCIe
Subject: RE: PCIe
Thanks & Regards
  srilakshmi
Subject: Re: PCIe
srilakshmi,
--Armin
> I need DMA stuff...
> Thanks & Regards
>   Srilakshmi
> Subject: Re: PCIe
>> Hi,
> --Armin
>> Thanks & Regards
>>    Srilakshmi
>> General
General
General
General
http://community.qnx.com/sf/go/post94387
To cancel your subscription to this discussion, please...
Re: PCIe
No
objdump -x nnn
qcc.exe
> Thanks & Regards
>    Srilakshmi
> Subject: Re: PCIe
> Subject: RE: PCIe
> Thanks & Regards
>    srilakshmi
> Subject: Re: PCIe
> srilakshmi,
> --Armin
>> I need DMA stuff...
>> Thanks & Regards
>>    Srilakshmi
>> Subject: Re: PCIe
>>> Hi,
>> --Armin
>>> Thanks & Regards
>>>     Srilakshmi
>>> General
>> General
>> General
RE: PCIe
I Think I got wrong information from you
Sent: Thursday, July 26, 2012 12:41 AM
Subject: Re: PCIe
No
objdump -x nnn
qcc.exe
> Thanks & Regards
>    Srilakshmi
> Subject: Re: PCIe
> Subject: RE: PCIe
> Thanks & Regards
>    srilakshmi
> Subject: Re: PCIe
> srilakshmi,
> --Armin
>> I need DMA stuff...
>> Thanks & Regards
>>    Srilakshmi
>> Subject: Re: PCIe
>>> Hi,
>> --Armin
>>> Thanks & Regards
>>>     Srilakshmi
>>> General
>> General
>> General
Re: PCIe
so what's wrong ?
> Subject: Re: PCIe
> No
> objdump -x nnn
> qcc.exe
>> Thanks & Regards
>>     Srilakshmi
>> Subject: Re: PCIe
>> Subject: RE: PCIe
>> Thanks & Regards
>>     srilakshmi
>> Subject: Re: PCIe
>> srilakshmi,
>> --Armin
>>> I need DMA stuff...
>>> Thanks & Regards
>>>     Srilakshmi
>>> Subject: Re: PCIe
>>>> Hi,
>>> --Armin
>>>> Thanks & Regards
>>>>      Srilakshmi
>>>> General
RE: PCIe
From  AIMB580(Advantech Intel Mother Board) I am connecting PCIe to Master
FPGA card(Xilinx).
When QNX system is booting up at that time PCIe detecting Master FPGA card
with as Address locations(BAR) are enabled.
When I power off for Master FPGA card, at that time pcie is not detecting.
again When I power ON for Master FPGA ,card PCIe was detecting but all
Memory locations are disabled & Interrupt line also no connection.
Now I want solution for
Even when I Power off or Power ON for Master FPGA at that time also PCIe
should detect with Address locations(BAR) status as enabled.
Please send me solution as early as possible.
Thanks & Regards
  Srilakshmi
RE: PCIe
FPGA card(Xilinx).
Thanks & Regards
  Srilakshmi
RE: PCIe
FPGA card(Xilinx).
Thanks & Regards
  Srilakshmi
FPGA card(Xilinx).
Thanks & Regards
  Srilakshmi
ks & Regards
>>    Srilakshmi
>> General
General
General
General
