Want my .so libraries to be loaded run time
07/14/2012 2:20 AM
post94255
Hi, I am recently started using QNX IDE for my work. Here i have a new module in .so lib format and also i have test app
to test my lib. Bu whenever i start my test app in debug mode,i am able to keep breakpoints in t the code that
corresponds to my test app, but where as if try setting brk point in my driver code, then i see below error "No source
file named XXXXX.c". then when i open the module list i see the my test app in loaded state where as my.so lib in not
loaded state. Can you help what i need to do so that the lib also always gets loaded?
Srinivas
