Forum Topic - Chmod:
Chmod
   I am running qnx from CDROM drive and the files to run are on a USB drive.
   I am trying to change permission on the files but it seem not changing.
  I type
  chmod 755 "filename"   ---it seem the command was accepted but when I do
  ls -l the permission stays at -rw-rw-rw-
Pls any suggestions
Re: Chmod
Probably because it's a dos filesystem on the usb drive.
Try copying them to /dev/shmem and then do the chmod.
On Fri, Apr 06, 2012 at 11:54:00AM -0400, Ismail Muse wrote:
>   I type
> Pls any suggestions
> http://community.qnx.com/sf/go/post92481
Re: Chmod
Thanks I am able to change permissions and run the program. Thanks
