Forum Topic - Automatic log in:
Automatic log in
If I log in manually and then run a program that calls "phshutdown -u -S user" I get returned to the standard login
prompt. If I log in automatically and run the same program I just get left with a blank command window when I really
want the  standard login prompt again. Any ideas?
I enabled automatic login by adding "login -f username" to /etc/rc.d/rc.local and running ph from .profile. Same happens
 if instead I run "Photon -l 'phlogin -O -U username" from rc.local (paths excluded for brevity).
I am running NTO 6.5.0 VMWare image downloaded from QSS, logging into photon and
using a photon app to change users.
