Forum Topic - using SNMP API to read data (OID) from an SNMP agent:
is there any help, or example for using the snmp api functions like snmp_open(), snmp_send()...? I'm lost with the
description in the library reference.
I use a QNX 6.4.1 system and would like to read out OIDs from another SNMP agent.
The snmp_open() succeeds, but the snmp_send() with my snmp-get-pdu failes with error -1 (general error). Is this the
right way to read from a SNMP agent?
Here is my source code.
Thanks for any help!
Carsten
extern int snmp_errno;
snmp_session* m_Session;
int SnmpCallback (int operation, struct snmp_session* session, int reqid, struct snmp_pdu* pdu, void* magic)
  printf("SnmpCallback\n");
  // TODO
  return 1; // successful completion
    oid   BaseOid[] = {1,3,6,1,4,1,4329,1};
    char  AgentIpAddress[] = "192.168.184.200";
    snmp_session snmp_session_settings;
    snmp_session_settings.community = 0; // default
    snmp_session_settings.community_len = SNMP_DEFAULT_COMMUNITY_LEN; // default
    snmp_session_settings.retries = 0; // no retries
    snmp_session_settings.timeout = SNMP_DEFAULT_TIMEOUT;
    snmp_session_settings.peername = AgentIpAddress; // agent ip address 192.168.184.200
    snmp_session_settings.remote_port = 161; // UDP Port at agent
    snmp_session_settings.local_port = 162; // local UDP port for traps
    snmp_session_settings.authenticator = NULL; // not authentication used
     snmp_session_settings.callback = (int (*)())(SnmpCallback); // callback for async answers and traps
    snmp_session_settings.callback_magic = NULL;
    snmp_session_settings.version = SNMP_VERSION_2;
    snmp_session_settings.srcParty = BaseOid;
    snmp_session_settings.srcPartyLen = sizeof(BaseOid)/sizeof(oid);
    snmp_session_settings.dstParty = BaseOid;
    snmp_session_settings.dstPartyLen  = sizeof(BaseOid)/sizeof(oid);
    snmp_session_settings.context = BaseOid;
    snmp_session_settings.contextLen = sizeof(BaseOid)/sizeof(oid);
    m_Session = snmp_open(&snmp_session_settings);
    if(m_Session == NULL)
      printf("Error %d in snmp_open\n", snmp_errno);
    else
      printf("snmp_open done!\n");
    long Value = 0;
    oid   AnyOID[] = {1,3,6,1,4,1,4329,1,2,4};
    variable_list new_variable;
    new_variable.name = &AnyOID[0];
    new_variable.name_length = sizeof(AnyOID);
    new_variable.next_variable = NULL;
    new_variable.type = ASN_INTEGER;
    new_variable.val.integer = &Value;
    new_variable.val_len = sizeof(Value);
    ipaddr theIpAddr;
    memset(&theIpAddr, 0, sizeof(theIpAddr));
    theIpAddr.sin_len = sizeof(theIpAddr);
    theIpAddr.sin_family = AF_INET;
    theIpAddr.sin_port = htons((uint16_t)162);
    theIpAddr.sin_addr.s_addr = __IPADDR(0xC0A4B801); //192.168.184.1
    // create a new pdu struct
    struct snmp_pdu * new_snmp_pdu = snmp_pdu_create (GET_REQ_MSG);
    // fill the pdu struct
    new_snmp_pdu->version = m_Session->version;
    new_snmp_pdu->address = theIpAddr;
    new_snmp_pdu->srcParty = m_Session->srcParty;
    new_snmp_pdu->srcPartyLen = m_Session->srcPartyLen;
    new_snmp_pdu->dstParty = m_Session->dstParty;
    new_snmp_pdu->dstPartyLen = m_Session->dstPartyLen;
    new_snmp_pdu->context = m_Session->context;
    new_snmp_pdu->contextLen = m_Session->contextLen;
    new_snmp_pdu->community = m_Session->community;
    new_snmp_pdu->community_len = m_Session->community_len;
//  new_snmp_pdu->command =  allready filled
    new_snmp_pdu->reqid = 1;
    new_snmp_pdu->agent_addr = theIpAddr;
//  new_snmp_pdu->trap_type :don't know
//  new_snmp_pdu->specific_type :don't know
//  new_snmp_pdu->time  :use default
    new_snmp_pdu->variables  = &new_variable;
    int returnvalue = snmp_send( m_Session,
                               new_snmp_pdu...
Attachment: Text SNMP_Test.cc 4.05 KB
Re: using SNMP API to read data (OID) from an SNMP agent
From grows tired from Help also.
Please anybody do explain, please, why is the variables srcParty, dstParty, context are equal when are initialize? What
they are mean?
Thanks or answer.
incorrect hex IP, it must be  0xC0A8B801
what is mean the requid variable? where can I find a Help on SNMP structs?
