Forum Topic - Create ETFS Filesystem: (3 Items)
How would one go about creating an ETFS-based efs image in Momentics? When creating a new efs, Momentics only gives you
the option to create an ffs3 or ffs2 filesystem (Properties -> Filesystem Type).
Am I correct in thinking that ffs3 is only for NOR devices while ETFS is for NAND devices?
Re: Create ETFS Filesystem
> creating a new efs, Momentics only gives you the option to create an ffs3 or
Unfortunately, the Momentics system builder does not support the ETFS filesystem at this time. However, we do have the
mketfs command line utility you can use.
> NAND devices?
You are correct.
Cheers,
Joel
> filesystem at this time. However, we do have the mketfs command line utility
> you can use.
Are there any plans to support the ETFS filesystem in the system builder?
