Forum Topic - Thank you for your support: (2 Items)
Result of uname as below.
# uname -a
QNX localhost 6.4.1 2009/05/20-17:35:31EDT x86pc x86
----- Original Message -----
>What is the output from:
># uname -a
>Please paste output here.
>On Wed, 2010-09-01 at 04:29 -0400, Kengo Kinoshita wrote:
>> We had met unable difficulty problem.
>> At now, every process were stoping at __i686.get_pc_thunk.cx () from /usr/qnx641/target/qnx6/x86/lib/libc.so.3
>> And we could not continue debugging procedure.
>> Backtrace log is following.
>> (gdb) file TickStub
>> Reading symbols from /root/pac/Unit/Source/private/HWJitterTest/TickStub...done.
>> (gdb) b main
>> Breakpoint 1 at 0x8049ccd: file main.c, line 644.
>> (gdb) run
>> Starting program: /root/pac/Unit/Source/private/HWJitterTest/TickStub
>> [New pid 741415 tid 1]
>> Program received signal 0, Signal 0.
>> 0xb0319254 in __i686.get_pc_thunk.cx () from /usr/qnx641/target/qnx6/x86/lib/libc.so.3
>> (gdb) continue
>> Continuing.
>> (gdb) continue
>> Continuing.
>> (gdb) bt
>> #0  0xb0319254 in __i686.get_pc_thunk.cx ()
>> #1  0xb033ff15 in _dl_debug_state () at /home/builder/hudson/641/svn/lib/c/ldd/ldd.c:1001
>> #2  0xb0342f7d in ldd (frame=0x8047bc8)
>>     at /home/builder/hudson/641/svn/lib/c/ldd/ldd.c:193
>> #3  0xb033f110 in _start_ () from /usr/qnx641/target/qnx6/x86/lib/libc.so.3
>> (gdb)
>> General
>> http://community.qnx.com/sf/go/post65384
>General
>http://community.qnx.com/sf/go/post65412
RE: Thank you for your support
Have you tried remote debugging?
From: Kengo Kinoshita [mailto:community-noreply@qnx.com]
Sent: Wed 9/1/2010 6:59 PM
To: general-community
Subject: Thank you for your support
# uname -a
># uname -a
>> (gdb) file TickStub
>> (gdb) b main
>> (gdb) run
>> (gdb) continue
>> Continuing.
>> (gdb) continue
>> Continuing.
>> (gdb) bt
>> (gdb)
>> General
>General
General
http://community.qnx.com/sf/go/post65579
Attachment: Text winmail.dat 3.37 KB
