Forum Topic - Now I begin to start the porting job that porting dd utility from NetBSD to QNX6.4.0.: (3 Items)
Hello
I am Japanese software engineer.
and Source code of dd(NetBSD edition) was already downloaded and already try to rebuild on QNX6.4.0.
But many errors happen,
So I am very confused those errors are see bellow(used Makefile)
Makefile:7: *** missing separator.
and simply gcc using as bellow.
Please teach me something solve operations regarding the porting job.
# gcc dd.c -o dd
In file included from /root/NetBSD/usr/src/include/rpc/types.h:41,
                 from /root/NetBSD/usr/src/sys/sys/mtio.h:37,
                 from dd.c:53:
/root/NetBSD/usr/src/sys/arch/hpc/stand/include/machine/types.h:21: error: expected '=', ',', ';', 'asm' or
'__attribute__' before 'int64_t'
/root/NetBSD/usr/src/sys/arch/hpc/stand/include/machine/types.h:26: error: expected '=', ',', ';', 'asm' or
'__attribute__' before 'uint64_t'
/root/NetBSD/usr/src/sys/arch/hpc/stand/include/machine/types.h:32: error: expected '=', ',', ';', 'asm' or
'__attribute__' before 'u_int64_t'
/root/NetBSD/usr/src/sys/arch/hpc/stand/include/machine/types.h:38: error: conflicting types for 'time_t'
/usr/qnx640/target/qnx6/usr/include/time.h:46: error: previous declaration of 'time_t' was here
In file included from dd.c:66:
dd.h:45: error: expected specifier-qualifier-list before 'uint64_t'
dd.h:61: error: expected specifier-qualifier-list before 'uint64_t'
In file included from dd.c:67:
extern.h:58: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'cpy_cnt'
extern.h:59: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'cbsz'
extern.h:62: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'progress'
dd.c:80: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'cpy_cnt'
dd.c:83: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'cbsz'
dd.c:85: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'progress'
dd.c: In function 'main':
dd.c:107: error: 'SIGINFO' undeclared (first use in this function)
dd.c:107: error: (Each undeclared identifier is reported only once
dd.c:107: error: for each function it appears in.)
dd.c: In function 'setup':
dd.c:126: error: 'IO' has no member named 'name'
dd.c:127: error: 'IO' has no member named 'name'
dd.c:128: error: 'IO' has no member named 'fd'
dd.c:130: error: 'IO' has no member named 'fd'
dd.c:130: error: 'IO' has no member named 'name'
dd.c:131: error: 'IO' has no member named 'fd'
dd.c:132: error: 'IO' has no member named 'name'
dd.c:136: error: 'IO' has no member named 'fd'
dd.c:141: error: 'IO' has no member named 'flags'
dd.c:146: error: 'IO' has no member named 'name'
dd.c:148: error: 'IO' has no member named 'fd'
dd.c:149: error: 'IO' has no member named 'name'
dd.c:153: error: 'IO' has no member named 'fd'
dd.c:153: error: 'IO' has no member named 'name'
dd.c:153: error: 'DEFFILEMODE' undeclared (first use in this function)
dd.c:159: error: 'IO' has no member named 'fd'
dd.c:160: error: 'IO' has no member named 'fd'
dd.c:160: error: 'IO' has no member named 'name'
dd.c:161: error: 'IO' has no member named 'flags'
dd.c:163: error: 'IO' has no member named 'fd'
dd.c:164: error: 'IO' has no member named 'name'
dd.c:169: error: 'IO' has no member named 'fd'
dd.c:179: error: 'IO' has no member named 'dbsz'
dd.c:185: error: 'IO' has no member named 'dbsz'
dd.c:185: error: 'cbsz' undeclared (first use in this function)
dd.c:186: error: 'IO' has no member named 'dbsz'
dd.c:194: error: 'IO' has no member named 'offset'
dd.c:196: error: 'IO' has no member named 'offset'
dd.c:204: error: 'IO' has no member named 'fd'
dd.c:204: error: 'IO' has no member named 'offset'
dd.c:204: error: 'IO' has no member named 'dbsz'
dd.c:241: error: 'STAT' has no member...
Re: Now I begin to start the porting job that porting dd utility from NetBSD to QNX6.4.0.
> Hello
> QNX6.4.0.
Are you sure that you need to port dd?
There is  one already:
http://developers.qnx.com/developers/docs/6.4.0/neutrino/utilities/d/dd.html
You can simply use it right away.
-Jeevan
On Wed, Aug 04, 2010 at 04:33:47AM -0400, Kengo Kinoshita wrote:
> Hello
I guess the first question is why do you want to
port the NetBSD one?  What's wrong with the
shipped dd?
NetBSD uses bsd make (bmake), not gnu make.
> # gcc dd.c -o dd
>                  from dd.c:53:
> dd.c:169: error: 'IO' has no member named...
