Forum Topic - sshd manual installation: (3 Items)
I have an embedded system which is un-writable (must be flashed).  I am trying to manually install sshd.  I try to start
 sshd giving it path to key and the config file.  But I get
Privilege separation user sshd does not exist
I created a sshd user with this;
passwd:
sshd:x:74:481:Privilege-separated SSH::
group:
sshd:x:481
shadow:
sshd:!!:14769::::::
But I still get this message.
Thank you,
Durwin
Re: sshd manual installation
start sshd giving it path to key and the config file.  But I get
> passwd:
Check out the normal install.  The above should look like:
sshd:x:74:481:sshd:/var/chroot/sshd:/bin/false
/var/chroot/sshd must exist and should have owners/perms like:
drwxr-xr-x  2 root      root           1024 Jun 02 13:55 /var/chroot/sshd
> group:
> sshd:x:481
> shadow:
> sshd:!!:14769::::::
> Thank you,
> Durwin
> http://community.qnx.com/sf/go/post58298
Thank you.  I shall give that a try.  Right now I am busy recovering from a server hardware failure.
