Re: QNXv6.4.1 instalaation fails when you update the disk drivers devb-brmm provided with the installation.
03/17/2010 10:56 AM
post49756
> I am trying to install QNXv6.4.1 on compact flash on an Intel atom platform.
You are installing from CD you say. However, the CD isn't meant to be installed on an Embedded system. Although it would
be great to have such a CD for easy installation, it doesn't exist. The CD that does exist is only for 'self-hosted'
development, e.g. if you are developing QNX code right under QNX, or to use as a life-CD to test hardware compatibility.
For your system, I suggest you create a IFS (Image File System = file that contains the OS and some basic drivers) on a
different machine, could even be a Windows machine, using QNX Momentics Tool Suite. Include the necessary driver in your
IFS.
- Malte
