Forum Topic - QNX SDP 6.6 binary compatibility on a QNX SDP 6.5 target:
Hi guys,
I understood that binaries produced by QNX 6.5 toolchain will work on QNX 6.6 targets. I was wondering whether the other
 way around would work. So, I created a hello world application which basically does a printf, compiled with QNX 6.6's
QCC, deployed on a QNX 6.5 target and that worked. However, when I was using std::pow, it threw a memory fault.
Here is the test code:
#include <stdio.h>
#include <math.h>
int main()
  double result = std::pow(2.0, 2);
  printf("Result: %lf\n", result);
  return 0;
Compile with: QCC -Vgcc_ntoarmv7le -Bstatic -lcpp math.cpp -lm.
Note: I statically linked the program against libcpp and libm using the -Bstatic option. Can somebody confirm that this
is the right way to statically link to the static libcpp library.
Best regards,
Anton
Re: QNX SDP 6.6 binary compatibility on a QNX SDP 6.5 target
On 14-09-22 03:54 AM, Anton Indrawan wrote:
> Hi guys,
other way around would work. So, I created a hello world application which basically does a printf, compiled with QNX 6.
6's QCC, deployed on a QNX 6.5 target and that worked. However, when I was using std::pow, it threw a memory fault.
Running newer binaries on older versions of the OS might work, but it's
not guaranteed to work so it's an unsupported use case.
this is the right way to statically link to the static libcpp library.
Yes, but leaving it without a -Bdynamic, means the -lc that the compiler
drivers automatically link in will be statically linked as well. If you
want to create a full static binary, then you should link with -static.
If you still want dynamically linked program, you need to link against
libc.so, in which case you should to do, -Bstatic -lcpp -Bdynamic
Ryan Mansfield
> > Hi guys,
> 6 targets. I was wondering whether the other way around would work. So, I
>  QNX 6.6's QCC, deployed on a QNX 6.5 target and that worked. However, when I
Anton: Thanks for your reply. I will take that input into account.
> Bstatic option. Can somebody confirm that this is the right way to statically
> Regards,
> Ryan Mansfield
@Ryan:
Anton: I tried the following command
QCC -Vgcc_ntoarmv7le -Bstatic -lcpp -Bdynamic helloworld.cpp
but the resulting binary still contains a dependency to the shared libcpp library.
  Tag        Type                         Name/Value
 0x00000001 (NEEDED)                     Shared library: [libcpp.so.5]
 0x00000001 (NEEDED)                     Shared library: [libc.so.3]
I am not sure how I can just statically link to the static libcpp library.
Could you also reproduce it?
@Mario: If I could use the QNX 6.6 toolchain for building binaries (at least with statically linked libcpp library)
which can be deployed on a QNX 6.5 target, it would save me lots of linking time. In my case, linking my big app using
the QNX 6.5's ld takes ~15-20 minutes or even more, while using QNX 6.6's ld is much faster. I am not sure how fast it
is, but it won't take longer than 5 minutes.
Anton
RE: QNX SDP 6.6 binary compatibility on a QNX SDP 6.5 target
-----Message d'origine-----
De : Anton Indrawan [mailto:community-noreply@qnx.com]
Envoyé : 22 septembre 2014 17:09
À : general-toolchain
Objet : Re: QNX SDP 6.6 binary compatibility on a QNX SDP 6.5 target
>  using the QNX 6.5's ld takes ~15-20 minutes or even more, while using QNX 6.6's ld is much faster.
>  I am not sure how fast it is, but it won't take longer than 5 minutes.
Can't you just use 4.8.3 and the bin utils for 6.5.0 ?
Anton
General
http://community.qnx.com/sf/go/post111830
To cancel your subscription to this discussion, please e-mail general-toolchain-unsubscribe@community.qnx.com
Re: RE: QNX SDP 6.6 binary compatibility on a QNX SDP 6.5 target
Hi Mario,
Will this work on a standard QNX 6.5 target?
I don't make the target image, so I don't really know if this would work.
Best regards,
Anton
Yes that is exactly what I`m doing.  There is release of 4.8.3 for 650 and another 4.8.3 for 6.6.0.
Hi Mario,
Thanks for your information.
However, the libcpp.so under the GCC 4.8.3 seems to intentionally be pointing to a non-existent file. I am not sure if I
 can take it from the standard QNX 6.5 toolchain. I will give it a try later.
Best regards,
Anton
RE: RE: QNX SDP 6.6 binary compatibility on a QNX SDP 6.5 target
Dinkum is not supply with 4.8.3, you must use gnu ( libstdc++.so ), sorry should have mentioned that.
QNX Support offered to build me a version of the Dinkum libs, but I declined, switching to libstdc++ turned out to be
positive for us.  Had I known I would have switch to it earlier.
Envoyé : 26 septembre 2014 16:13
Objet : Re: RE: QNX SDP 6.6 binary compatibility on a QNX SDP 6.5 target
Hi Mario,
Best regards,
Anton
General
http://community.qnx.com/sf/go/post111901
On 14-09-22 05:08 PM, Anton Indrawan wrote:
> @Ryan:
>    Tag        Type                         Name/Value
When you link C++, qcc automatically links against libcpp. You should
specify -nostdlib++. e.g.
$ qcc  math.cpp -Bstatic -lcpp -lcxa -lm -Bdynamic -nostdlib++
$ ntox86-readelf -d a.out | grep NEEDED
One problem you might hit trying to get 6.6.0 binaries to run on 6.5.0,
is that everything is built is with -fstack-protector, which relies on
support in libc. This wasn't in the 6.5.0 libc but IIRC, 6.5.0SP1 added.
Ryan Mansfield
Hi Ryan,
This works well. Thank you.
Best regards,
Anton
> Thanks,
> Anton
@Mario/@Ryan,
What is the exact tag/release of bin utils that is required/recommended to use the 4.8.3 compiler targeting QNX 6.5?
And would this then support C++11 library?
John
Ryan doesn't seem to be working for QNX anymore.
Currently using 2.24.
And yes C++11 works, mostly, as 4.8.3 is not fully compliant.
De : John Hagen [mailto:community-noreply@qnx.com]
Envoyé : 21 janvier 2016 18:37
À : general-toolchain <general-toolchain@community.qnx.com>
> Thanks,
> Anton
@Mario/@Ryan,
John
General
http://community.qnx.com/sf/go/post115585
Why would you want to do that ?
Envoyé : 22 septembre 2014 03:55
Objet : QNX SDP 6.6 binary compatibility on a QNX SDP 6.5 target
Hi guys,
#include <stdio.h>
#include <math.h>
int main()
  return 0;
Best regards,
Anton
General
http://community.qnx.com/sf/go/post111814
