Forum Topic - Building Samba Server: (7 Items)
I'm trying to build samba in Momentics...
On Linux, I'd do a ./configure && make...
How do I do this the most elegant way with Momentics, doing cross-platform devel for ARM?
Markus
Re: Building Samba Server
On Thu, Jul 21, 2011 at 07:35:22AM -0400, Markus Heider wrote:
Same way self hosted.
> doing
I find the easiest way is to parse the steps the
package uses to create the x86 version above and
convert it to our recursive make structure.  YMMV.
RE: Building Samba Server
There is rudimentary support for autoconf packages in the build system, but it is undocumented.  It revolves around the
use of qmake-cfg.mk and the build-cfg script.
From: Sean Boudreau [mailto:community-noreply@qnx.com]
Sent: Thu 2011-07-21 08:46
To: general-toolchain
Subject: Re: Building Samba Server
> doing
General
http://community.qnx.com/sf/go/post87489
I know but I find it hit and miss.  YMMV :)
> but it is undocumented.  It revolves around the use of qmake-cfg.mk and
> > Hi,
> > doing
> Regards,
> -seanb
> http://community.qnx.com/sf/go/post87492
Yes, it is definitely tricky to get it set up right (although that is chiefly a function of how good the autoconf is in
the first place).
I think of it more as "Hit and hit and hit and hit... until it stops moving." ;-)
Sent: Thu 2011-07-21 08:58
> > Hi,
> > doing
> Regards,
> -seanb
General
http://community.qnx.com/sf/go/post87493
Thanks for your Replies.
> > Hi,
you mean running Linux in a VM?
> > doing
How do you mean that?
> > > Hi,
No, I mean install qnx natively on an x86 machine.  There's
3 host platforms for momentics (the qnx tools): windows,
linux and native (qnx).  In this scenario linux is not
involved, the same way qnx is not involved when you build
samba or whatever on linux.  If you use a vm it would be
qnx in the vm.
You can build samba 3.5 for x86 from pkgsrc:
http://community.qnx.com/sf/projects/pkgsrc
http://community.qnx.com/sf/wiki/do/viewPage/projects.pkgsrc/wiki/Bootstrap
# (cd pkgsrc/net/samba3.5 && bmake install)
> > > doing
This is the layout the ide sets up when you instantiate
a 'C project' therein.
