Forum Topic - How to transfer test program/files from Host to VM ware based QNX image. : (9 Items)
        I have an Audio test program built using QNX momentics on my XP machine. I also have a VMware imgae of QNX
running on the same machine. Is it possible to transfer this test program's binary and a test audio file over to the
VMware image instance of QNX ? I would appreciate any pointers and hints on how to go about doing so. As a first step it
 be great if someone could tell me how to transfer files to the VMWare image.
Vijay
Re: How to transfer test program/files from Host to VM ware based QNX image.
Are you using IDE? There is 10 Steps guide that describe how to write simple program and launch it using IDE.
If you don't want to use IDE for some reason you can used ftp, scp, etc.
On 29/11/10 12:46 PM, Vijay Dixit wrote:
> Hello,
> Thanks,
> Vijay
> http://community.qnx.com/sf/go/post76294
Yes I am using the IDE, how may I go about using SCP/FTP from XP ? Any specific software/driver to be installed on the
QNX side ?
If you using IDE you have to read the guide (at least 10 steps one!). You just launch the application - it will transfer
 all files for you. Also you can use Target File System Natigator view
to drag and drop files between host & target.
software/driver to be installed on the QNX side ?
> http://community.qnx.com/sf/go/post76320
Hello Elena,
                Thanks for the hint. But after spending a while with the IDE am unable to exactly find, how to bring up
the drag and drop feature from within the IDE ?
Vijay
Did you read 10 Steps guide?
http://www.qnx.com/developers/docs/6.5.0/index.jsp?topic=/com.qnx.doc.momentics_quickstart/about.html
On 29/11/10 02:52 PM, Vijay Dixit wrote:
> Hello Elena,
up the drag and drop feature from within the IDE ?
> Thanks,
> Vijay
> http://community.qnx.com/sf/go/post76323
Elena, thanks a lot for the above link. That certainly helps. Will give it a try.
Vijay
Elena,
           I am using the QNX momentics suite downloaded from here:
http://www.qnx.com/products/evaluation/
I am unable to find a way to add the QNX Audio library to build my program, as described in the link above. The IDE that
 I have is quite different from the one being used in the article. I seem to have a newer one. Any hints on how I may
add a shared library to build my project ?
Vijay
I had to create a QNX-C project and that resolved it.
