Qt 5.2.0 dev env for linux with target binaries/plugins dependent in libstdc++ and not libstdcpp(-ne)
02/20/2015 12:09 PM
post113361
I am using the released binaries for Qt. 5.2.0 on Linux and notice that they are dependent on the libstdcpp library.
The project I am working on consistently depends on the libstdc++ (GNU C++) library.
I've noticed that the Qt libraries depend on the libstdcpp (Dinkum C++) library.
Our Qt application is compiled/linked with the GNU C++ library, but the Dinkum C++ library is pulled in from the
applications Qt library dependencies. This is causing run-time failures as two C++ libraries are loaded by the
application.
Do you have a Qt 5.2.0 development environment compiled/linked against the GNU C++ library?
I do not have the ability to convert the rest of the project to the Dinkum C++ library.
Thank you,
Steven Zajac
