Re: How to run QNX terminal in qws?
12/12/2013 7:19 AM
post107465
I assume you want to run "shell" while Qt is running?
1. Unless running on x86, you can add '&' to the Qt command line and have use of the shell
2. You can enable telnet login
3. You can enable a login on another serial port (tinit)
