Forum Topic - 3D QT Support for QNX: (2 Items)
Dear All,
Could you please share some information if it is possible to port 3D QT applications to QNX?
Do we need to add extra libraries while building host and target environment to run 3D applications?
All replies will be highly appreciated.
Re: 3D QT Support for QNX
Hi Seyfettin,
You can definitely port a 3D application to QNX.   If you are talking specifically about a Qt application that uses the
QtOpenGL module you should just need to build your application using the Qt packages posted on in the File Releases
section and your application will be able to run on QNX OS 6.6.    Can you post more specifics about the application you
 would like to port?
- Tim -
