11/15/2017 6:11 AM
post118204
Hello Ulrich,
The snmp_open() call uses malloc() to allocate memory for internal data. Don't you forget to call snmp_close()? If not
then can you post here tarball with minimal working example that illustrates the problem?
14 нояб. 2017 г., в 13:48:12, Mailaender, Ulrich <community-noreply@qnx.com> написал:
> Hello QNX admins,
> I am using snmp to read some information from an external device. Therefore I link snmp3r.lib and socket3r.lib so I am
able to use function snmp_open (), ….
> There is no problem with the function itself. The problem is, the DATA memory is increasing all the time!!
> Is there any update or other solution about this problem??
> (using tcp/ip version 5.1)
> BR Ulrich
