Forum Topic - QNX 4.25 and Logitech K400r USB keyboard with touch pad:
Been trying to get these two to play. Keyboard works fine, but cant seem to get the touchpad to function. /dev/usbmouse0
 does appear post io-usb & and devu-mouse &. Just cant seem to find Input args to get it to work.
Any help would be much appreciated,
Thanks.
Re: QNX 4.25 and Logitech K400r USB keyboard with touch pad
Hi Joseph,
Please post here how you tried to you launch Input. Also add output of usb -v command.
11 нояб. 2015 г., в 8:16:48, joseph kocsis <community-noreply@qnx.com> написал:
usbmouse0 does appear post io-usb & and devu-mouse &. Just cant seem to find Input args to get it to work.
> Thanks.
> http://community.qnx.com/sf/go/post114954
Thanks for your reply Oleg.
Attached are the outputs of usb -v and usb -vvv.
Input has failed to get the touchpad working with the following arguments:
Input msys fd -d/dev/usbmouse0 &
Input msoft fd -d/dev/usbmouse0 &
Input generic fd -d/dev/usbmouse0 &
Attachment: Text usb-v.txt 943 bytes Text usb-vvv.txt 2.4 KB
Hi Joseph,
I should get the same keyboard next week, so I’ll test it and post here my results.
12 нояб. 2015 г., в 1:16, joseph kocsis <community-noreply@qnx.com> написал:
> http://community.qnx.com/sf/go/post114968
> <usb-vvv.txt><usb-v.txt>
Hi Joseph,
I’ve got the similar keyboard and I’ve looked deeper into the issue. It seems that mouse protocol is different than
that is supported in devu-mouse. So I should update the devu-mouse to support the protocol.
Another solution is to use keyboard in compatible mode and do not launch io-usb for the keyboard. Does it work for you?
12 нояб. 2015 г., в 1:16:09, joseph kocsis <community-noreply@qnx.com> написал:
Hi Oleg,
Thanks for your effort.
Unfortunately I require io-usb to be running for other purposes.
If devu-mouse could be updated to include the required protocol that would be great.
Joseph
