Forum Topic - Iso9660fsys problem:
Iso9660fsys problem
Hello QNX4 specialists!
I'm actually testing the IntelAdvancedMAnagementTechnology for the usage in our QNX4 environmetn and have a problem with
 a remotely mounted ISO image:
Testenv:
SIEMENS PC with IAMT (Intel Advanced MAnagement Technology)
Remote PC uses VNCviewer+ to come to the screen of the SIEMENS
Mounted an ISO image of the remote PC from the SIEMENS
Result:
Fsys.atapi shows the remotely mounted ISO as local CD drive
spatch or dd shows me that the /dev/cd0 offers the QNX4 the content of the remote ISO
But:
Iso9660fsys
or
Iso9660fsys -s
mount_iso9660 /dev/cd0 /cd0
does not offer the content of the ISO.
The mount makes no problem!
What can I do at he Iso9660fsys or at mount_iso9660 to get the filesys content?
Re: Iso9660fsys problem
Hi Klaus,
Maybe there is a problem with the ISO image. What file system type used in
the ISO image? Can you mount the ISO image in the QNX4 locally using
following command?
# Iso9660fsys /cd2=/path/to/iso/image
Can you burn the ISO image to CD? Is this CD working correctly when it
mounted locally in the QNX4?
> usage in our QNX4 environmetn and have a problem with a remotely
> mounted ISO image:
> Testenv:
> Result:
> the remote ISO
> But:
> Iso9660fsys
> or
> Iso9660fsys -s
> content?
> http://community.qnx.com/sf/go/post84118
Hi Oleg,
locally everything is working fine.
I can mount the ISO if I use a VMWare and I can burn the ISO on CD and use it in any PC.
The ISO is a bootable (-b bootimage) ISO with long filenames (-l),leading dots (-L) and RockRidge (-R) in the filesys.
No Joliet.
The call is:
mkisofs -o /tmp/pantest.iso -b bootimage -l -L -R /CD_DIR
I also tried now without RockRidge but also without success.
If I use the 2010 QNX installation the "Auto-detecting Hardware ..."  is working properly at the beginning.
But after detection of hardware the installer is waiting 30 seconds for the /dev/cd0.0 and have no success to access it.
Therefore I cant continue the installation at his point and I assume that there is the exactly same problem the cause.
Greetings from a still alive QNX4 user;)
Klaus
Hi Oleg,
the QNX6.5 CD is booting withou any problem and I can run the system from CD.
Hi Klaus,
Unfortunately, I don't have Intel AMT PC here, so more time will be
required to reproduce and resolve this issue. I'll contact you when here
will be any news.
> Hi Oleg,
> use it in any PC. The ISO is a bootable (-b bootimage) ISO with long
> filenames (-l),leading dots (-L) and RockRidge (-R) in the filesys. No
> Joliet.
> The call is:
> is working properly at the beginning. But after detection of hardware
> success to access it. Therefore I cant continue the installation at
> cause.
> Klaus
> http://community.qnx.com/sf/go/post84153
