Forum Topic - dhcpd not quite working:
I have a issue as you can see below.  Can anyone tell me where to start.  If this is not enough information to
understand the problem, let me know.  From one line it says function not implemented.  If it can't commit a lease, then
it is completely useless is it not?
# dhcpd -d -cf /mnt/etfs/etc/dhcpd.conf -lf /tmp/dhcpd.leases -pf /mnt/etfs/etc/dhcpd.pid
Internet Software Consortium DHCP Server V3.0pl2
Copyright 1995-2003 Internet Software Consortium.
All rights reserved.
Wrote 0 leases to leases file.
commit_leases: unable to commit: Function not implemented
Listening on Socket/en0/192.168.1.0/24
Sending on   Socket/en0/192.168.1.0/24
DHCPDISCOVER from 00:26:6c:87:5f:d1 via en0
DHCPOFFER on 192.168.1.250 to 00:26:6c:87:5f:d1 (ursa) via en0
Can't create new lease file: Not enough memory
DHCPREQUEST for 192.168.1.250 (192.168.1.2) from 00:26:6c:87:5f:d1 (ursa) via en
0: database update failed
Re: dhcpd not quite working
Is /tmp a RAM disk? How big is it?
>   If this is not enough information to understand the problem, let me
> a lease, then it is completely useless is it not?
> (ursa) via en
> (ursa) via en
> (ursa) via en
> Technology
> http://community.qnx.com/sf/go/post81558
Yes, 19M
Even if I run following command I get similar results.
# dhcpd -d -cf /mnt/etfs/etc/dhcpd.conf -lf /mnt/etfs/etc/dhcpd.leases -pf /mnt/etfs/etc/dhcpd.pid
# Internet Software Consortium DHCP Server V3.0pl2
# Copyright 1995-2003 Internet Software Consortium.
# All rights reserved.
# Wrote 0 leases to leases file.
# Can't backup lease database /mnt/etfs/etc/dhcpd.leases to /mnt/etfs/etc/dhcpd.le
# ases~: Improper link
# Listening on Socket/en0/192.168.1.0/24
# Sending on   Socket/en0/192.168.1.0/24
# DHCPDISCOVER from 00:26:6c:87:5f:d1 via en0
# DHCPOFFER on 192.168.1.250 to 00:26:6c:87:5f:d1 (ursa) via en0
# Can't create new lease file: Not enough memory
# DHCPREQUEST for 192.168.1.250 (192.168.1.2) from 00:26:6c:87:5f:d1 (ursa) via en
# 0: database update failed
> > (ursa) via en
> > (ursa) via en
> > (ursa) via en
> > Technology
Does the leases file exist? touch /tmp/dhcpd.leases
> Yes, 19M
> (ursa) via en
> (ursa) via en
> commit
>  > > (ursa) via en
>  > > (ursa) via en
>  > > (ursa) via en
>  > > _______________________________________________
>  > > Technology
> Technology
> http://community.qnx.com/sf/go/post81575
Yes it does.  I make sure after each reboot.
> > Yes, 19M
> > (ursa) via en
> > (ursa) via en
> > commit
> >  > > (ursa) via en
> >  > > (ursa) via en
> >  > > (ursa) via en
> >  > > Technology
> > Technology
RE: dhcpd not quite working
Are you using devb-ram or another file system driver. It may be that the
driver does not support all file system operations. The not enough
memory responses are odd though.
Dave
> From: Durwin De La Rue [mailto:community-noreply@qnx.com]
> Sent: January 7, 2011 5:02 PM
> To: technology-networking
> Subject: Re: dhcpd not quite working
> > > Yes, 19M
> 00:26:6c:87:5f:d1
> > > (ursa) via en
> 00:26:6c:87:5f:d1
> > > (ursa) via en
> to start.
> let me
> can't
> > > commit
> -pf
en0
> 00:26:6c:87:5f:d1
> > >  > > (ursa) via en
> 00:26:6c:87:5f:d1
> > >  > > (ursa) via en
> > >  > > 0: database update...
Re: RE: dhcpd not quite working
> Dave
What ever driver is running the shared memory (/tmp) and what ever driver runs the nand flash (/mnt/etfs) fails.  I do
not know the drivers.  But when we mount the SD card and use it, DHCPD works.  So for now, we will do just that.  Thank
you for your time.
Durwin
> > > > Yes, 19M
> > 00:26:6c:87:5f:d1
> > > > (ursa) via en
> > 00:26:6c:87:5f:d1
> > > > (ursa) via en
> > to start.
> > let me
> > can't
> > > > commit
> > -pf
Replying as I ran into this problem 8 years later ...
Trying to keep dhcpd.leases in /tmp won't work as it is using the RAM filesystem. Put on any other filesystem however
will work. Reason is found in the QNX documentation:
"Note that /dev/shmem isn't actually a filesystem. It's a window onto the shared memory names that happens to have some
filesystem-like characteristics."
I finally got my dhcpd.leases working from RAM using ramdrive formatted as FAT:
    devb-ram ram nodinit,cache=512k disk name=hd@10
    waitfor /dev/hd10
    fdisk /dev/hd10 add -t 6
    mount -e /dev/hd10
    waitfor /dev/hd10t6
    mkdosfs /dev/hd10t6
    mount -t dos /dev/hd10t6 /root
    mkdir /root/leasesdb
    touch /root/leasesdb/dhcpd.leases
    chmod a+rw /root/leasesdb/dhcpd.leases
    dhcpd -lf /root/leasesdb/dhcpd.leases ural0
Hope this saves some time to the next guy
Thank you Ivo Kostadinov.  That did help!
