Re: RE: dhcpd not quite working
01/11/2011 1:47 PM
post81898
> Are you using devb-ram or another file system driver. It may be that the
> driver does not support all file system operations. The not enough
> memory responses are odd though.
> Dave
What ever driver is running the shared memory (/tmp) and what ever driver runs the nand flash (/mnt/etfs) fails. I do
not know the drivers. But when we mount the SD card and use it, DHCPD works. So for now, we will do just that. Thank
you for your time.
Durwin
> > From: Durwin De La Rue [mailto:community-noreply@qnx.com]
> > Sent: January 7, 2011 5:02 PM
> > To: technology-networking
> > Subject: Re: dhcpd not quite working
> > > Does the leases file exist? touch /tmp/dhcpd.leases
> > Yes it does. I make sure after each reboot.
> > > On 11-01-07 04:47 PM, Durwin De La Rue wrote:
> > > > > Is /tmp a RAM disk? How big is it?
> > > > Yes, 19M
> > > > Even if I run following command I get similar results.
> > > > # dhcpd -d -cf /mnt/etfs/etc/dhcpd.conf -lf
> > /mnt/etfs/etc/dhcpd.leases
> > > > -pf /mnt/etfs/etc/dhcpd.pid
> > > > # Internet Software Consortium DHCP Server V3.0pl2
> > > > # Copyright 1995-2003 Internet Software Consortium.
> > > > # All rights reserved.
> > > > # Wrote 0 leases to leases file.
> > > > # Can't backup lease database /mnt/etfs/etc/dhcpd.leases to
> > > > # ases~: Improper link
> > > > # Listening on Socket/en0/192.168.1.0/24
> > > > # Sending on Socket/en0/192.168.1.0/24
> > > > # DHCPDISCOVER from 00:26:6c:87:5f:d1 via en0
> > > > # DHCPOFFER on 192.168.1.250 to 00:26:6c:87:5f:d1 (ursa) via en0
> > > > # Can't create new lease file: Not enough memory
> > > > # DHCPREQUEST for 192.168.1.250 (192.168.1.2) from
> > 00:26:6c:87:5f:d1
> > > > (ursa) via en
> > > > # 0: database update failed
> > 00:26:6c:87:5f:d1
> > > > (ursa) via en
> > > > > On 11-01-07 03:09 PM, Durwin De La Rue wrote:
> > > > > > I have a issue as you can see below. Can anyone tell me where
> > to start.
> > > > > > If this is not enough information to understand the problem,
> > let me
> > > > > > know. From one line it says function not implemented. If it
> > can't
> > > > commit
> > > > > > a lease, then it is completely useless is it not?
> > > > > > # dhcpd -d -cf /mnt/etfs/etc/dhcpd.conf -lf /tmp/dhcpd.leases
> > -pf
> > > > > > commit_leases: unable to commit: Function not implemented
