Forum Topic - Brainteaser #1 (multi-threaded NetBSD drivers): (2 Items)
"How do you make a NetBSDdriver operate in a multi-threaded mode? (Code snippet required.)"
I did a diff between the original NetBSD drivers and the ones under sys/dev/ic/. The notes in sys/dev/doc/port_bsd.txt
were also quite helpful.
In order to port a NetBSD driver one has to sprinkle NW_SIGLOCK() and NW_SIGUNLOCK() throughout the source because the
interrupt handler is atomic under NetBSD but can be interrupted under QNX.
For the two drivers I looked into (i82557.c, rt2560.c) the function xxx_start() has to be called with the lock held.
Making a NetBSD driver multi-threaded can be achieved by changing the call to
    pci_intr_establish(pc, ih, IPL_NET, fxp_intr, sc);
to
    pci_intr_establish_exten(pc, ih, IPL_NET, fxp_intr, sc, 0);
Take a look at pci_conv_qnx.c, line 450:
void *
pci_intr_establish(pci_chipset_tag_t pc, pci_intr_handle_t ih, int level,
    int (*func)(void *), void *arg)
	 * By default the porting lib throws IRUPT_NOTHREAD
	 * which will pare the stack down to single threaded
	 * pulse mode.  If you're sure the driver in question
	 * does all the right things WRT locking, use
	 * pci_intr_establish_exten().
	return pci_intr_establish_exten(pc, ih, level, func, arg,
	    IRUPT_NOTHREAD);
BUT: As the comment above says: One has to make sure locking is correct!
Is this the code snippet you have in mind?
Re: Brainteaser #1 (multi-threaded NetBSD drivers)
> snippet required.)"
> sys/dev/ic/. The notes in sys/dev/doc/port_bsd.txt were also quite
> helpful.
> NW_SIGUNLOCK() throughout the source because the interrupt handler is
> call to
> to
> void *
> level,
> 	    IRUPT_NOTHREAD);
A+ from me.
