Re: Samba Client, and Server
02/15/2010 6:06 AM
post47300
> On 09/02/10 09:19 AM, Malte Mundt wrote:
> >> Check out fs-cifs whcih ships with 6.4.x
> > AFAIK there are different authentification algorithms across various Windows
> versions. E.g. in older versions you do not need to specify a domain, and fs-
> cifs will try '*' as the domain, etc.
> > Does the 6.4.1 fs-cifs actually support mounting shared folders from a
> Windows 2003 server? The docs only mention Windows NT 'or other SMB servers'.
> FWIW, I just used 6.4.1 fs-cifs to mount a shared folder on a Windows
> 2003 server.
> Try yourself, and if you speak SMB then you can look at the packet
> capture to see what dialects and domains etc are used...
> Hope this helps you!
> /P
Thanks Patrik!
