Re: Is it possible for io-pkt to release (purge) open socket file
descriptors?
08/19/2009 3:30 PM
post36327
descriptors?
On Wed, Aug 19, 2009 at 01:49:18PM -0400, maurice gibbs wrote:
> Hi I'm chasing an odd problem.
> Here's a snippet of code:
> tempFD = socket( PacketFamily, SOCK_STREAM, 0 );
> setsockopt( tempFD, SOL_SOCKET, SO_REUSEADDR, (char *) &one,
> sizeof(int));
> bindReturn = bind( tempFD, (struct sockaddr *) &sock,
> sizeof(sock));
> if ( listen( tempFD, backlog) == 0)
> while( ! tc_is_shutdown() )
> FD_ZERO( &readSet );
> FD_SET( tempFD, &readSet );
> timeout.tv_sec = 1;
> timeout.tv_usec = 0;
> result = select( tempFD + 1, &readSet, 0, 0, &timeout );
> if (result == -1)
> break;
> else if (result == 0)
> if ( tc_is_shutdown() )
> break;
> else
> continue;
> if ( ! FD_ISSET( tempFD, &readSet ) )
> continue;
> ses_handle = accept( tempFD, ( struct sockaddr *)&sock, &len);
> if (setsockopt(ses_handle, SOL_SOCKET, SO_RCVTIMEO,
> (char*)&tcptimeout, tcptimeoutLen) == -1)
> perror("Set SO_RCVTIMEO: FAILED")
> <more stuff here>
> Well, I've had a failure report come my way which pretty much indicates
> the following: the setsockopt() after the accept() returned a failure
> which indicated that the File Descriptor was invalid.
It depends on the errno from setsockopt(). You should also
check the return from accept().
> Question: under what circumstances would the io-pkt stack purge it's
> current file descriptor list (if ever)?
It should never do that.
