Forum Topic - UDP communication : (19 Items)
UDP communication
I'm testing an example application of the library "udt". The code of this example works with Linux and Windows.
Under QNX6.4.1 I got the following error message:
> bind: Connection setup failure: unable to create/configure UDP socket:
> No buffer space available.
Is UDP not supported ??
The code sequence is:
 int main(int argc, char* argv[])
   if ((1 != argc) && ((2 != argc) || (0 == atoi(argv[1]))))
      cout << "usage: appserver [server_port]" << endl;
      return 0;
   // use this function to initialize the UDT library
   UDT::startup();
   addrinfo hints;
   addrinfo* res;
   memset(&hints, 0, sizeof(struct addrinfo));
   hints.ai_flags = AI_PASSIVE;
   hints.ai_family = AF_INET;
   hints.ai_socktype = SOCK_STREAM;
   //hints.ai_socktype = SOCK_DGRAM;
   string service("9000");
   if (2 == argc)
      service = argv[1];
   if (0 != getaddrinfo(NULL, service.c_str(), &hints, &res))
      cout << "illegal port number or port is busy.\n" << endl;
      return 0;
   UDTSOCKET serv = UDT::socket(res->ai_family, res->ai_socktype, res->ai_protocol);
   // UDT Options
   //UDT::setsockopt(serv, 0, UDT_CC, new CCCFactory<CUDPBlast>, sizeof(CCCFactory<CUDPBlast>));
   //UDT::setsockopt(serv, 0, UDT_MSS, new int(9000), sizeof(int));
   //UDT::setsockopt(serv, 0, UDT_RCVBUF, new int(10000000), sizeof(int));
   //UDT::setsockopt(serv, 0, UDP_RCVBUF, new int(10000000), sizeof(int));
   if (UDT::ERROR == UDT::bind(serv, res->ai_addr, res->ai_addrlen))
      cout << "bind: " << UDT::getlasterror().getErrorMessage() << endl;
      return 0;
   freeaddrinfo(res);
.....  a.s.o
--Armin
Re: UDT communication
Yes, UDP is supported :-)
I am not familiar with this library and since the source code only has
the calls into what I assume is the library (and doesn't contain the
socket API calls) I'm afraid I can't point you at what is going on. I
have to assume therefore that it's doing some Linux-ism or something
else which won't fly on BSD style systems. Have you tried this on BSD?
/P
This is probably not the error coming from the QNX socket library,
sounds like something internal to UDT.
>     UDT::startup();
I have no idea what goes on inside ::startup, ::socket, ::bind methods
so cant' really say what (may) have gone wrong...
RE: UDT communication
I`m using the Poco library that implement UPD objects and it worked right out of the box.
> From: Patrik Lahti [mailto:community-noreply@qnx.com]
> Sent: Monday, May 17, 2010 9:29 AM
> To: general-networking
> Subject: Re: UDT communication
> /P
> socket:
> >     UDT::startup();
> res->ai_protocol);
> http://community.qnx.com/sf/go/post54843
Re: RE: UDT communication
> of the box.
Also the UDT library works out of the box ... but only for Linux and Windows.
The UDT lib is C++ based. What about the Poco lib ?
The ported code of the UDT lib is available at:
 http://community.qnx.com/sf/sfmain/do/downloadAttachment/projects.toolchain/discussion.core_development_tools.topc13742
/post54800?id=atch7679
It compiles as out of the box ... but doesn't work as out of the box.
-Armin
RE: RE: UDT communication
> From: Armin Steinhoff [mailto:community-noreply@qnx.com]
> Sent: Monday, May 17, 2010 3:58 PM
> Subject: Re: RE: UDT communication
> right out
> > of the box.
> Windows.
Yes it`s a C++ library very nice, it contains a lot more then UDP, it has TCP, HTTPD, XML and lots of other goodies:
http://pocoproject.org/.  I rarely stumble upon code that I look on and say I which I could program like this.  Poco is
one of them.  I don`t understand why it`s not as popular.
I compiles and works fine ;-)  I`m using 4 of the 5 freely available module, Foundation, Net, XML, Zip.
> hain/discussion.core_development_tools.topc13742/post54800?id=atch7679
> -Armin
> http://community.qnx.com/sf/go/post54893
Patrik,
just a statement to the "-ism".
Your approach of thinking is "QNX is right ... the rest of the world has
a failure".
No  ... the problem are QNX-ism.
It's still a pain to port a piece of C++ based software to QNX.
As a reality check ... try to recompile the ROOT system.  (
http://root.cern.ch )
And then ask why they are not using QNX ...
> or something
Why should it work with BSD?
On QNX you can recompile just 3000 of 9000 BSD packages. The reasons are
BSD-ism ??
Cheers
--Armin
But QNX *is* right :-)
Just kidding...
/P
Attachment: Text winmail.dat 2.03 KB
Re: UDP communication
Can you give a compiling example using this
library?
Sean,
the ported lib is available at:
http://community.qnx.com/sf/sfmain/do/downloadAttachment/projects.toolchain/discussion.core_development_tools.topc13742/
post54800?id=atch7679.
There is still for linking the libstdc++ to remove ...
Regards
--Armin
> library?
> Thanks,
> -seanb
> http://community.qnx.com/sf/go/post54962
On Tue, May 18, 2010 at 11:39:24AM -0400, Armin Steinhoff wrote:
> Sean,
topc13742/post54800?id=atch7679.
I downloaded it, and built it.  Now how do I reproduce your issue?
>> Sean,
In the directory app is located the "appserver". This example terminates
with an strange error message.
Regards
--Armin
Please see the attached diff.  You might want to go
through the other ifdefs.
Attachment: Text diff 521 bytes
And please send them back to the UDT people.
Sean,
I have checked all other idefs. The os spec in the Makefiles was also
not fully correct ... I changed it to UNIX.
After  recompiling and linking against the shared lib of udt ...
"appserver" terminaties with the same problem as before.
But the applications "appserver" and "appclients" are working after
linking against the _static_ library of udt!
IMHO ... this is a QNX-ism of QCC.  Should  I send this problem back to
the compiler/linker guys  ?
Regards
--Armin
> -seanb
> http://community.qnx.com/sf/go/post55026
On Wed, May 19, 2010 at 09:16:02AM -0400, Armin Steinhoff wrote:
> Sean,
Did you get rid of the -lstdc++ ?  With that change appserver
is working for me against the shared lib.
# pidin -p appserver me
     pid tid name               prio STATE            code  data        stack
  909350   1 ./appserver         10o CONDVAR           24K  168K   24K(516K)*
  909350   2 ./appserver         10o CONDVAR           24K  168K  4096(132K)
  909350   3 ./appserver         10o CONDVAR           24K  168K  4096(132K)
  909350   4 ./appserver         10o REPLY             24K  168K  4096(132K)
            libc.so.3          @b0300000             488K   16K
            libudt.so          @b8200000             236K  8192
            libcpp.so.4        @b823d000             376K   36K
            libm.so.2          @b82a4000             180K   24K
            libsocket.so.3     @b82d7000             164K   28K
Sean,
I removed -lstdc++, -lcpp and -lcxa  because all compilation was done
with QCC.
I'm using qnx 6.4.1 ...
--Armin
>> Sean,
> http://community.qnx.com/sf/go/post55144
> Sean,
> with QCC.
and compile /link natively ...
--Armin
> --Armin
> >> Sean,
> stack
> > General
On Wed, May 19, 2010 at 12:28:14PM -0400, Armin Steinhoff wrote:
> > Sean,
> > with QCC.
Of course, like all packet pushers should :)
I'm on 6.5 but I can't think why that should matter...
>>> Sean,
>>> with QCC.
Different binaries of compiler/linker ... different
environments/libraries on QNX6, Linux, Windows ?
I will repeat the test on 6.5 ...
--Armin
