04/14/2009 5:10 PM
post27003
Thank you for the fast response, it solved the problem
08/29/2012 8:17 PM
post95292
I have a similar problem. Bought a Belkin F5D7050, plugged into a powered hub and ran the following commands:
io-pkt-v4-hc -d /fs/hd1/lib/devnp-rum.so
wpa_supplicant -B -i rum0 -c /fs/hd1/etc/wpa_supplicant.conf
my conf file:
network={
ssid="mgtsciences"
key_mgmt=WPA-PSK
psk="abcdefghij"
ifconfig shows:
rum0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ssid "" nwkey 65536:"","","",""
powersave off
address: 94:44:52:03:ad:89
media: IEEE802.11 autoselect (DS1 mode 11g)
status: no network
sloginfo shows:
Jan 16 08:39:59 5 14 0 USB device vendor 0x50d, device 0x705a matched.
Jan 16 08:39:59 5 14 0 rum0 at pci0 dev 0 function 0rum0: MAC/BBP RT2573 (rev 0x2573a), RF RT2528, address 94:
44:52:03:ad:89
Jan 16 08:39:59 5 14 0 ether_ifattach: rum0 null if_stop
Jan 16 08:39:59 5 14 0 rum0: 11b rates: 1Mbps 2Mbps 5.5Mbps 11Mbps
Jan 16 08:39:59 5 14 0 rum0: 11g rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps
48Mbps 54Mbps
Jan 16 08:42:46 5 14 0 USB error 0x06000000 encountered in io-pkt.
Jan 16 08:42:51 5 14 0 USB error 0x06000000 encountered in io-pkt.
Jan 16 08:43:03 5 14 0 USB error 0x06000000 encountered in io-pkt.
Jan 16 08:43:08 5 14 0 USB error 0x06000000 encountered in io-pkt.
Jan 16 08:43:20 5 14 0 USB error 0x06000000 encountered in io-pkt.
Jan 16 08:43:31 5 14 0 USB error 0x06000000 encountered in io-pkt.
Any ideas?
Todd
> What type of target platform are you on? We have seen errors like that
> when the target wasn't capable of supplying enough power to the dongle.
> In those instances, we recommended plugging the dongle into a powered
> USB hub and that usually fixed things.
> R.
> From: Agoston Feher [mailto:community-noreply@qnx.com]
> Sent: Tuesday, April 14, 2009 12:35 PM
> To: drivers-networking
> Subject: USB WiFi hangs
> i have an issue with usb wifi connection i use io-pkt-v4-hc, the
> devnp-rum.so driver mounts without problem, i configure the network with
> wpa_supplicant, and i get ip address with dhcp everything seems fine but
> after some time - usually during heavy network traffic - the connection
> hangs.
> the board only has usb 1.1 controller but it should be compatible as far
> as i know. i also tried to limit the wifi speed by setting the mode and
> media parameters of the driver to different values but i had the same
> results.
> the board is Advantech PCI-6871
> the usb stick is ASUS WL-167g
> here is the output from sloginfo:
> Jan 12 00:09:03 5 14 0 en0USB device vendor 0xb05, device
> 0x1723 matched.
> Jan 12 00:09:03 5 14 0 rum0 at pci0 dev 0 function 0rum0:
> MAC/BBP RT2573 (rev 0x2573a), RF RT2528, address 00:1b:fc:8f:ff:96
> Jan 12 00:09:03 5 14 0 ether_ifattach: rum0 null if_stop
> Jan 12 00:09:03 5 14 0 rum0: 11b rates: 1Mbps 2Mbps 5.5Mbps
> 11Mbps
> Jan 12 00:09:03 5 14 0 rum0: 11g rates: 1Mbps 2Mbps 5.5Mbps
> 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps
> Jan 12 00:11:38 5 14 0 rum0: device timeout
> Jan 12 00:11:39 5 14 0 USB error 0x06000000 encountered in
> io-pkt.
> Jan 12 00:11:44 5 14 0 rum0: device timeout
> Jan 12 00:11:49 5 14 0 USB error 0x06000000 encountered in
> io-pkt.
> Jan 12 00:11:57 5 14 0 rum0: could not multi read MAC
> register: NOMEM
> Jan 12 00:13:34 5 14 0 rum0: could not multi read MAC
> register: NOMEM
> Jan 12 00:13:51 5 14 0 USB error 0x06000000 encountered in
> io-pkt.
> Jan 12 00:27:40 5 14 0...
