Forum Topic - QNX 7 E1000 Driver Very Slow Sending Only:
I have a QNX 7 machine with dual Intel NIC cards in it only 1 of which is plugged in.
Transferring files from this machine is incredibly slow but sending files is lightning fast.  I have another older QNX 6
 machine (different NIC hardware) on the same network and transferring files in both directions is fine.
QNX 6 Machine:
C:\Users\admin\transfer>ftp 172.27.12.103
Connected to 172.27.12.103.
220 172.27.12.103 FTP server ready.
502 Unknown command UTF8.
User (172.27.12.103:(none)): root
331 Password required for root.
Password:
230-
    Welcome to QNX Neutrino!
230 User root logged in.
ftp> bin
200 Type set to I.
ftp> put deviceMgr.core
200 PORT command successful.
150 Opening BINARY mode data connection for 'deviceMgr.core'.
226 Transfer complete.
ftp: 11628544 bytes sent in 0.38Seconds 31009.45Kbytes/sec.
ftp> get deviceMgr.core
150 Opening BINARY mode data connection for 'deviceMgr.core' (11628544 bytes).
ftp: 11628544 bytes received in 0.66Seconds 17726.44Kbytes/sec.
ftp>
QNX 7 machine
C:\Users\admin\transfer>ftp 172.27.12.3
Connected to 172.27.12.3.
220 172.27.12.3 FTP server (QNXNTO-ftpd 20081216) ready.
502 Unknown command 'UTF8'.
User (172.27.12.3:(none)): qnxuser
331 User qnxuser accepted, provide password for qnxuser@SurfaceController.
Password:
230-No directory! Logging in with home=/
230 User qnxuser logged in.
ftp> cd /tmp
250 CWD command successful.
ftp> bin
200 Type set to I.
ftp: 11628544 bytes received in 73.31Seconds 158.62Kbytes/sec.
ftp>
Note that incredibly slow transfer rate!
I start networking to use just 1 NIC with a static IP
io-pkt-v6-hc -d e1000 &
if_up -r 10 -p wm1
ifconfig wm0 up
ifconfig wm1 172.27.12.3 up
inetd &
Ifconfig reports:
# ifconfig -a
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
wm0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
        capabilities rx=1f<IP4CSUM,TCP4CSUM,UDP4CSUM,TCP6CSUM,UDP6CSUM>
        capabilities tx=7f<IP4CSUM,TCP4CSUM,UDP4CSUM,TCP6CSUM,UDP6CSUM,TSO4,TSO6>
        enabled=0
        address: 00:0b:ab:d6:bd:15
        media: Ethernet none
        inet6 fe80::20b:abff:fed6:bd15%wm0 prefixlen 64 scopeid 0x11
wm1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
        enabled=0
        address: 00:0b:ab:d6:bd:16
        media: Ethernet autoselect (1000baseT full-duplex,flowcontrol,rxpause,txpause)
        status: active
        inet 172.27.12.3 netmask 0xffff0000 broadcast 172.27.255.255
        inet6 fe80::20b:abff:fed6:bd16%wm1 prefixlen 64 scopeid 0x12
Nicinfo looks fine (gigabit, full duplex, no physical medium errors)
# nicinfo
wm0:
  INTEL PRO/1000 Gigabit (Copper) Ethernet Controller
  Link is DOWN
  Physical Node ID ........................... 000BAB D6BD15
  Current Physical Node ID ................... 000BAB D6BD15
  Current Operation Rate ..................... Unknown
  Active Interface Type ...................... MII
    Active PHY address ....................... 2
  Maximum Transmittable data Unit ............ 1500
  Maximum Receivable data Unit ............... 1500
  Hardware Interrupt ......................... 0x102
  Memory Aperture...
Re: QNX 7 E1000 Driver Very Slow Sending Only
The QNX6 and QNX7 e1000 drivers should be identical, so I don't know why you are having the slowdown on the QNX7 machine
. Can you run QNX6 on that machine and see if the driver behaves the same? Also, please post the output from "pci-tool -
vv" from the QNX7 machine.
Thanks, Hugh.
On 2018-01-19, 6:01 PM, "Tim Sowden(deleted)" <community-noreply@qnx.com> wrote:
QNX 6 machine (different NIC hardware) on the same network and transferring files in both directions is fine.
    QNX 6 Machine:
    Password:
    230-
    ftp> bin
    200 Type set to I.
    ftp>
    QNX 7 machine
    Password:
    ftp> cd /tmp
    ftp> bin
    200 Type set to I.
    ftp>
    if_up -r 10 -p wm1
    ifconfig wm0 up
    inetd &
    Ifconfig reports:
    # ifconfig -a
            enabled=0
            enabled=0
            status: active
Hi Hugh,
Below is the output you requested
Unfortunately I can't run QNX 6 on this hardware because the version we use is 6.32 and it's too old to handle the SATA
+ Network etc. That's one of the reasons we are upgrading to QNX 7 because our old hardware is becoming obsolete and we
can't get it anymore. So the QNX 6 test you saw was the same network but different computer hardware.
One thing that is different is that in 6.32 we have a net.cfg file that contains all the I/P stuff including gateways /
DNS servers etc. That file doesn't seem to exist in QNX 7 so as I showed in my prior post I just use ifconfig to set the
 IP and nothing else. But maybe it's gateway/DNS related since I don't set any of that specifically...
B000:D00:F00 @ idx 0
	vid/did: 8086/191f
		Intel Corporation, <device id - unknown>
	class/subclass/reg: 06/00/00
		Host-to-PCI Bridge Device
	revid: 7
	cmd/status registers: 6/2090
	Capabilities: 09 (VEND) --> *
	Address Space list - 0 assigned
	Interrupt list - 0 assigned
	hdrType: 0
		ssvid: 8086  Intel Corporation
		ssid:  2015
B000:D02:F00 @ idx 1
	vid/did: 8086/1912
	class/subclass/reg: 03/00/00
		PC Compatible VGA Display Controller
	revid: 6
	cmd/status registers: 7/10
	Capabilities: 09 (VEND) --> 10 (PCIe) --> 05 (MSI) --> 01 (PMI) --> *
	Address Space list - 3 assigned
	    [0] MEM, addr=de000000, size=1000000, align: 1000000, attr: 64bit ENABLED
	    [2] MEM, addr=c0000000, size=10000000, align: 10000000, attr: 64bit PREFETCH ENABLED
	    [4] I/O, addr=f000, size=40, align: 40, attr: 16bit ENABLED
	hdrType: 0
		ssid:  2212
B000:D20:F00 @ idx 2
	vid/did: 8086/a12f
	class/subclass/reg: 0c/03/30
		USB Serial Bus Controller (Intel eXtensible HCI)
	revid: 49
	cmd/status registers: 6/290
	Capabilities: 01 (PMI) --> 05 (MSI) --> *
	Address Space list - 1 assigned
	    [0] MEM, addr=df130000, size=10000, align: 10000, attr: 64bit ENABLED
	Interrupt list - 1 assigned (MSI)
	    Interrupt 0 on IRQ 257
	hdrType: 0
		ssid:  7270
B000:D20:F02 @ idx 3
	vid/did: 8086/a131
	class/subclass/reg: 11/80/00
		Other DA/DSP Controller
	revid: 49
	cmd/status registers: 6/10
	    [0] MEM, addr=df14e000, size=1000, align: 1000, attr: 64bit ENABLED
	hdrType: 0
		ssid:  7270
B000:D22:F00 @ idx 4
	vid/did: 8086/a13a
	class/subclass/reg: 07/80/00
		Other Simple Communications Controller
	revid: 49
	cmd/status registers: 2/10
	    [0] MEM, addr=df14d000, size=1000, align: 1000, attr: 64bit ENABLED
	hdrType: 0
		ssid:  1999
B000:D23:F00 @ idx 5
	vid/did: 8086/a102
	class/subclass/reg: 01/06/01
		SATA Mass Storage Controller (AHCI Interface)
	revid: 49
	cmd/status registers: 7/2b0
	Capabilities: 05 (MSI) --> 01 (PMI) --> 12 (SATA CFG) --> *
	Address Space list - 6 assigned
	    [0] MEM, addr=df148000, size=2000, align: 2000, attr: 32bit ENABLED
	    [1] MEM, addr=df14c000, size=100, align: 100, attr: 32bit ENABLED
	    [2] I/O, addr=f090, size=8, align: 8, attr: 16bit ENABLED
	    [3] I/O, addr=f080, size=4, align: 4, attr: 16bit ENABLED
	    [4] I/O, addr=f060, size=20, align: 20, attr: 16bit ENABLED
	    [5] MEM, addr=df14b000, size=800, align: 800, attr: 32bit ENABLED
	    Interrupt 0 on IRQ 256
	hdrType: 0
		ssvid: 8086  Intel...
When you run the "get file" on the QNX7 machine, where is the file being written to? The fact that the "put" works fine,
 tells me that the driver is working fine. Maybe this could be due to a file system slowdown, so could you try copying
the large file to another large file on the same system and see if it takes a while.
Thanks, Hugh.
On 2018-01-22, 10:13 AM, "Tim Sowden(deleted)" <community-noreply@qnx.com> wrote:
    Hi Hugh,
SATA + Network etc. That's one of the reasons we are upgrading to QNX 7 because our old hardware is becoming obsolete
and we can't get it anymore. So the QNX 6 test you saw was the same network but different computer hardware.
gateways / DNS servers etc. That file doesn't seem to exist in QNX 7 so as I showed in my prior post I just use ifconfig
 to set the IP and nothing else. But maybe it's gateway/DNS related since I don't set any of that specifically...
    	vid/did: 8086/191f
    	revid: 7
    	hdrType: 0
    		ssid:  2015
    	vid/did: 8086/1912
    	revid: 6
    	hdrType: 0
    		ssid:  2212
    	vid/did: 8086/a12f
    	revid: 49
    	hdrType: 0
    		ssid:  7270
    	vid/did: 8086/a131
    	revid: 49
    	hdrType: 0
    		ssid:  7270
    	vid/did: 8086/a13a
    	revid: 49
    	hdrType: 0
    		ssid:  1999
    	vid/did: 8086/a102
Hugh,
> written to? The fact that the "put" works fine, tells me that the driver is
> try copying the large file to another large file on the same system and see if
>  it takes a while.
The ftp 'get' command is being run on a Windows machine (ie getting the file from the QNX machine). That's why I showed
the same transfer on a QNX 6 machine to indicate the Windows machine isn't the problem.
It's transferring data *from* the QNX 7 machine that's slow. I've tried sending from a RAM drive in addition to the hard
 drive and it makes no difference so it's definitely not file I/O related. I don't think it's driver related either
since the transfer is fine in the other direction. I'm certain there must be some network configuration option that's
not right.
I can install Wireshark and do a capture but I am not sure if that's useful or not.
Tim
Tim,
After running the ftp in both directions on the QNX7 machine, can you please collect the output from "netstat -s" and
send it to me?
Thanks, Hugh.
On 2018-01-22, 2:32 PM, "Tim Sowden(deleted)" <community-noreply@qnx.com> wrote:
    Hugh,
    >  it takes a while.
showed the same transfer on a QNX 6 machine to indicate the Windows machine isn't the problem.
hard drive and it makes no difference so it's definitely not file I/O related. I don't think it's driver related either
not right.
    Tim
    Networking Drivers
    http://community.qnx.com/sf/go/post118427
    To cancel your subscription to this discussion, please e-mail drivers-networking-unsubscribe@community.qnx.com
Are you running 32-bit or 64-bit under QNX7?
    Hugh,
    >  it takes a while.
not right.
    Tim
    Networking Drivers
Hugh,
We are using the 32 bit version of QNX 7. As an FYI, our recompiled (from 6.3) S/W on QNX 7 is crashing all over the
place with suspicious memory related errors and we are allocating some large chunks (8 megs). Not sure if that  means
anything.
Even the transfer of the results of the netstat commands is wildly varying.
Password:
ftp> cd /fs/ram
ftp> get tim
150 Opening ASCII mode data connection for 'tim' (12611 bytes).
ftp: 13020 bytes received in 1.02Seconds 12.81Kbytes/sec.
ftp> get tim1
150 Opening ASCII mode data connection for 'tim1' (12611 bytes).
ftp: 13020 bytes received in 0.00Seconds 13020000.00Kbytes/sec.
ftp> get tim2
150 Opening ASCII mode data connection for 'tim2' (12611 bytes).
ftp> quit
221-
    Data traffic for this session was 39060 bytes in 3 files.
    Total traffic for this session was 39919 bytes in 3 transfers.
221 Thank you for using the FTP service on 172.27.12.3.
File tim = state of system before doing anything (in case you needed base numbers)
File tim1 = state of system after transferring file to QNX (the good direction)
File tim2 = state of system after transferring file from QNX (the bad direction)
Tim
Attachment: Text tim 12.71 KB Text tim1 12.71 KB Text tim2 12.71 KB
RE: QNX 7 E1000 Driver Very Slow Sending Only
Seeing a lot of TCP retransmit timeouts & ICMP errors -- have you got a really congested link or flapping port between
the 2 hosts (possible bad switchport or cable)?
Under TCP stats:
tim:   4616 retransmit timeouts
tim1:  4616 retransmit timeouts
tim2:  4702 retransmit timeouts
Under ICMP stats:
tim:  261737 calls to icmp_error
            destination unreachable:  261737
tim1:  261748 calls to icmp_error
            destination unreachable:  261748
tim2:  261933 calls to icmp_error
            destination unreachable:  261933
Re: RE: QNX 7 E1000 Driver Very Slow Sending Only
>  congested link or flapping port between the 2 hosts (possible bad
switchport
> or cable)?
> Under TCP stats:
> Under ICMP stats:
The computers are all located in a lab with no outside access (closed network) so there is very little traffic.
I swapped Ethernet cables on the chance it might have been a bad cable I used but that made no difference. I was *this*
close to writing back when I decided to switch ports on the Netgear router. I hadn't done that prior because I had
plugged into a port that was being used by another computer in our lab so I *knew* it was good.
Of course the instant I plugged into another port everything started working in both directions. So the port must have
been degraded after all and just no one has noticed because they haven't transferred any large amount of data in the bad
 direction on the prior machine that was plugged in there!
One final question though. I swore prior versions of QNX showed these types of hardware issues in Nicinfo which was the
first place I went when I was having problems. The fact there were no errors reported there made me think it was a
configuration issue vs a hardware one.
Thanks for all your help,
Tim
