Buffer handling within an io-pkt transmit routine
02/18/2015 2:44 PM
post113328
Firstly pardon my lack of knowledge on this subject. I am attempting to write my first io-pkt driver, I have written
some io-net drivers a number of years ago (10). I have looked at the sam example code and my driver appears to be
mounted under io-pkt. I am having some problems with the transmit routine.
The hardware is in effect a SLIP interface, I am attempting to port from another well know RTOS towards QNX. On the
other RTOS I registered the driver as an Ethernet Interface and then in the Transmit routine jump over the Ethernet
Header. The hardware does not support DMA so the packet needs to be copied into a memory mapped transmit buffer. I was
hoping to be able to do the same under QNX.
I appear to have got some way towards this; the transmit routine is called but I am unable to successfully transmit the
mbuf data to the transmit buffer. I am however able to transmit a hardcoded buffer containing an ICMP echo request
packet. I de-fragment the received mbuf and have attempt to copy the packet into the transmit buffer using memcpy or
m_copydata without success.
Any help gratefully received.
Re: Buffer handling within an io-pkt transmit routine
02/18/2015 3:08 PM
post113330
m_copydata() is the right way to go, it copies data from an mbuf chain starting "off" bytes from the beginning,
continuing for "len" bytes, into the indicated buffer. Note that in Tx you are likely to get the data in an mbuf chain,
the dequeue will give you the first mbuf of the chain so you will need to walk the chain - that's why m_copydata() is so
nice as it walks the complete chain for you.
Have you tried also copying to just a static buffer and then printing that out? Can you share some code snippets?
02/18/2015 3:22 PM
post113331
Many thanks for the reply
So the following works
uint8_t test[] = {0x45,0x00,0x00,0x2e,0x7b,0x3a,0x00,0x00,0x3f,0x11,0x7b,0xb3,0xc0,0xa8,0x01,0x82,0xc0,0xa8,0x01,
0xff,0x1d,0x76,0x1d,0x76,0x00,0x1a,0xee,0x6c,0x20,0x8f,0x61,0x00,0x20,0x00,0x00,0xa5,0x07,0xb0,0xe0,0x00,0x00,0x00,0x00,
0x00,0x00,0x00};
memcpy(register_configuration->transmit_buffer, test, sizeof(test));
*(register_configuration->transmit_length_register) = sizeof(test);
*(register_configuration->transmit_control_register) = TRANSMITTER_START;
What I was trying was
uint8_t ethernet_media_access_control_address[] = {0x57, 0x20, 0x48, 0x4F, 0x45, 0x59, 0x57, 0x20, 0x48, 0x5F, 0x55,
0x69, 0x08, 0x00};
m_copydata(m, sizeof(ethernet_media_access_control_address), ((m->m_pkthdr.len)-
(sizeof(ethernet_media_access_control_address))), register_configuration->transmit_buffer);
*(register_configuration->transmit_length_register) = ((m->m_pkthdr.len)-
(sizeof(ethernet_media_access_control_address)));
I am currently trying to print the packet in some nicely formatted way, for some reason any printf call with formatting
arguments appear to end up in the slog.
02/18/2015 3:26 PM
post113332
fprintf won't go to slog.
Sent from my BlackBerry 10 smartphone on the Rogers network.
Original Message
Sent: Wednesday, February 18, 2015 3:22 PM
To: drivers-networking
Reply To: drivers-networking@community.qnx.com
Subject: Re: Buffer handling within an io-pkt transmit routine
0x00,0x00,0x00};
0x69, 0x08, 0x00};
Networking Drivers
http://community.qnx.com/sf/go/post113331
To cancel your subscription to this discussion, please e-mail drivers-networking-unsubscribe@community.qnx.com
02/18/2015 4:09 PM
post113333
A dump of the packet sent when I set the IP address with ifconfig gives the following:
ff ff ff ff ff ff 57 20 48 4f 45 59 08 06 00 01
08 00 06 04 00 01 57 20 48 4f 45 59 c0 a8 01 82
00 00 00 00
Which I think is a correctly formatted ARP packet.
02/18/2015 4:13 PM
post113334
What's the CPU and how does it behave in terms of strongly or weakly ordered memory? Presumably all those register
configuration pointers are volatile so the compiler shouldn't reorder them?
02/18/2015 4:45 PM
post113335
The CPU is an PowerPC 750 variant and all the registers are defined as volatile.
02/19/2015 9:17 AM
post113341
On PowerPC I think you need to add some "eioio" instructions to act as barriers and prevent it reordering accesses.
02/19/2015 5:03 AM
post113339
Armed with Sean's advice with regards to using fprint I think I have a better handle on what is going on.
I suspect that the transmit routine is working correctly, the first packet is ARP packet which is not forwarded by the
router on the other end of the SLIP interface.
Could the issue be related to how the device is registered with io-pkt?
The IP stack on the other RTOS only supports ethernet, so the drivers registers as an ethernet driver and sets the
following flags during initialisation:
xxxFlagSet(&network_device_configuration->end, IFF_POINTOPOINT | IFF_NOARP | IFF_SIMPLEX | IFF_BROADCAST | IFF_UP | IFF_RUNNING);
Under QNX in the attach routine I set the following flags:
ifp->if_flags = IFF_POINTOPOINT | IFF_NOARP | IFF_SIMPLEX | IFF_BROADCAST;
I then set the IFF_RUNNING runnnig in the initialisation routine.
I suspect I need to do a little bit more under io-pkt as ifconfig gives the following:
Other RTOS:
lo0 Link type:Local loopback Queue:none
inet 127.0.0.1 mask 255.255.255.255
UP RUNNING LOOPBACK MULTICAST NOARP ALLMULTI
MTU:1500 metric:1 VR:0 ifindex:1
RX packets:203 mcast:0 errors:0 dropped:0
TX packets:203 mcast:0 errors:0
collisions:0 unsupported proto:0
RX bytes:217k TX bytes:217k
fr0 Link type:1 HWaddr 57:20:48:4f:45:59 Queue:none
inet 192.168.1.130 mask 255.255.255.0 broadcast 192.168.1.255
UP RUNNING SIMPLEX BROADCAST NOARP
MTU:1500 metric:1 VR:0 ifindex:2
RX packets:376 mcast:0 errors:0 dropped:0
TX packets:158 mcast:0 errors:0
RX bytes:39k TX bytes:137k
QNX
fr0: flags=88d3<UP,BROADCAST, RUNNING,NOARP,SIMPLEX > mtu 1500
address: 57:20:48:4f:45:59
media: Ethernet none
inet 192.168.1.130 -> 192.168.1.255 netmask 0xffffff00 broadcast 192.168.1.255
On this piece of hardware the link is always available and there is no phy or link management required, is it possible
under io-pkt to simply hard code the link to be 10BaseT Full Duplex always UP? or can io-pkt support a SLIP interface
(as this would avoid the need for the network driver to add and remove the Ethernet Header)?
Many Thanks Again.
02/19/2015 9:22 AM
post113342
We do actually have lsm-slip.so to support SLIP. In this we set:
sc->sc_if.if_flags = IFF_POINTOPOINT | SC_AUTOCOMP | IFF_MULTICAST;
sc->sc_if.if_type = IFT_SLIP;
And then we if_attach() but we do NOT ether_ifattach()
02/19/2015 1:17 PM
post113343
Many thanks again; I am hoping that this will resolve my problems;
I have having some problems resolving the SC_AUTOCOMP definition.
With regard to the nic_config_t configuration I was considering the following:
network_device_configuration->nic_config.num_irqs = 1;
network_device_configuration->nic_config.irq[0] = IRQ_FOUR
network_device_configuration->nic_config.priority = IRUPT_PRIO_DEFAULT;
network_device_configuration->nic_config.lan = network_device_configuration->dev.dv_unit;
network_device_configuration->nic_config.iftype = IFT_SLIP;
network_device_configuration->nic_config.media = NIC_MEDIA_CUSTOM;
network_device_configuration->nic_config.mtu = ETH_MAX_PKT_LEN;
network_device_configuration->nic_config.mru = ETH_MAX_PKT_LEN;
network_device_configuration->nic_config.mac_length = 0;
network_device_configuration->nic_stats.media = network_device_configuration->nic_config.media;
But I am unclear if this is required.
02/19/2015 2:07 PM
post113344
Sorry about that, SC_AUTOCOMP is mapped through to IFF_LINK2 and is just used to flag auto-enable of the SLIP
compression.
The nic_config_t is more used my nicinfo which sends a SIOCGDRVCOM ioctl for DRVCOM_CONFIG and expects the nic_config_t.
You may not need to support this, although it is a nice way to dump out many of the internals. What you have looks
reasonable at a quick glance.
02/19/2015 2:16 PM
post113345
Can I ask is the source for lsm-slip.so publicly available?
When I set the IFF_POINTOPOINT | IFF_LINK2 | IFF_MULTICAST flags I get the following when I attempt to assign an IP
address.
ifconfig: SIOCAIFADDR: No such process
So more work required.
SLIP does feel like the best fit but I am wondering if an ethernet driver with the link hardcoded to 10BaseT Full Duplex
is the path of least resistance (this is what was necessary on the original RTOS) also the hardware can be configured
to automatically add and remove an ethernet header (however this is currently done in the driver but can be off loaded
to the hardware if necessary). Is it possible to effectively hard code the link configuration and remove the MII status
detection under io-pkt?
02/19/2015 2:23 PM
post113346
lsm-slip.so source code is not publicly available but may be available to you as part of your support contract.
It's perfectly possible to just not hookup the MII code for an Ethernet driver. See the dm814x driver published in
source code form in the J5 and J6 BSPs - when built with SWITCHMODE defined then it avoids the MII configuration and
just configures the MAC speed and duplex based on the command line option.
02/20/2015 8:56 AM
post113351
Nick,
Many thanks for all your help, I think I understand what is going on however not how to fix it.
On the current RTOS I set the following Interface Flags:
However under QNX if I set the IFF_NOARP flag I do not get the behaviour that I was hoping for.
Currently I print each packet in the Network Transmit routine, I have include this debug below.
When I assigned an IP address to the interface starts an ARP packet is transmitted.
# ifconfig fr0 192.168.1.130
HDLC Transmit Packet Length 42
0000 ff ff ff ff ff ff 57 20 48 4f 45 59 08 06 00 01
000f 08 00 06 04 00 01 57 20 48 4f 45 59 c0 a8 01 82
001f 00 00 00 00 00 00 c0 a8 01 82
# ifconfig
fr0: flags=8d3<UP,BROADCAST,POINTOPOINT,RUNNING,NOARP,SIMPLEX> mtu 1500
media: Ethernet 10baseT full-duplex (<unknown subtype> full-duplex)
If I attempt to ping a target on the network no packet is sent.
# ping -c1 192.168.1.54
PING 192.168.1.54 (192.168.1.54): 56 data bytes
----192.168.1.54 PING Statistics----
1 packets transmitted, 0 packets received, 100% packet loss
However if I manually add an ARP entry for the IP address and attempt to ping the packet is successfully transmitted on
the network.
# arp -s 192.168.1.54 00:67:54:34:35:17 fr0
HDLC Transmit Packet Length 98
0000 00 67 54 34 35 17 57 20 48 4f 45 59 08 00 45 00
000f 00 54 00 19 00 00 ff 01 37 87 c0 a8 01 82 c0 a8
001f 01 36 08 00 96 43 90 07 00 00 00 00 00 7f 00 02
002f e6 30 08 09 0a 0b 0c 0d 0e 0f 10 11 12 13 14 15
003f 16 17 18 19 1a 1b 1c 1d 1e 1f 20 21 22 23 24 25
004f 26 27 28 29 2a 2b 2c 2d 2e 2f 30 31 32 33 34 35
005f 36 37
02/20/2015 9:19 AM
post113352
Make sure you're not calling ether_ifattach().
On Fri, Feb 20, 2015 at 08:56:00AM -0500, William Hoey wrote:
> Nick,
> # ifconfig
on the network.
> 005f 36 37
> Networking Drivers
> http://community.qnx.com/sf/go/post113351
02/20/2015 9:27 AM
post113353
I am clearly missing something very obvious (sorry about that) I tried removing the call to ether_ifattach that results
in the following when I attempt to assign an IP address.
02/20/2015 9:34 AM
post113354
Sounds like io-pkt is faulting; maybe in your driver. Looking at the core file with the debugger or running io-pkt in
the debugger should give more info.
Original Message
Sent: Friday, February 20, 2015 9:27 AM
Networking Drivers
http://community.qnx.com/sf/go/post113353
02/20/2015 10:39 AM
post113355
Apart from the serial port this network driver is the only way into the board.
What appears to happen is if ether_ifattach is not called io-pkt terminates either setting or getting the interface
address
io-pkt-v4 -dnetwork-device
# pidin
pid tid name prio STATE Blocked
1 1 procnto-600_exp508 0f READY
1 2 procnto-600_exp508 255r RECEIVE 1
1 3 procnto-600_exp508 255r RECEIVE 1
1 4 procnto-600_exp508 11r RECEIVE 1
1 5 procnto-600_exp508 255r RECEIVE 1
1 6 procnto-600_exp508 10r RUNNING
1 7 procnto-600_exp508 10r RECEIVE 1
1 8 procnto-600_exp508 10r RECEIVE 1
1 9 procnto-600_exp508 10r RECEIVE 1
1 10 procnto-600_exp508 10r RECEIVE 1
1 11 procnto-600_exp508 10r RECEIVE 1
2 1 proc/boot/slogger 21r RECEIVE 1
3 1 proc/boot/pipe 10r SIGWAITINFO
3 2 proc/boot/pipe 10r RECEIVE 1
3 3 proc/boot/pipe 10r RECEIVE 1
4 1 proc/boot/devc-pty 10r RECEIVE 1
5 1 proc/boot/ksh 10r SIGSUSPEND
6 1 roc/boot/io-pkt-v4 21r SIGWAITINFO
6 2 roc/boot/io-pkt-v4 21r RECEIVE 1
4103 1 proc/boot/pidin 10r REPLY 1
Entered Function Network Device IOCTL -2138019572
Exit Function Network Device IOCTL
Entered Function Network Device IOCTL -2138019568
# pidin
1 4 procnto-600_exp508 10r RUNNING
1 6 procnto-600_exp508 11r RECEIVE 1
20487 1 proc/boot/pidin 10r REPLY 1
# ifconfig
Entered Network Device Stop Function
Exit Network Device Stop Function
ifconfig: getifaddrs: Bad file descriptor
# pidin
2 1 proc/boot/slogger 10r RECEIVE 1
40966 1 proc/boot/pidin 10r REPLY 1
02/20/2015 10:54 AM
post113357
address
It's probably faulting. Run 'dumper' and transfer the resulting core file
over serial and look at it in the debugger.
02/20/2015 11:03 AM
post113359
Downloading the core file possible when using devc-pty?
The debug prints in the driver code a not executed, and apart from the ARP issue works as expected when ether_ifattach
is called.
02/20/2015 2:23 PM
post113362
Sorry about my last post (cut and paste error). I was trying to determine if it was possible to obtain a dumper log
using devc-pty.
I was wondering if there was any example code available of an io-pkt network driver (of a type other than Ethernet or
WiFi). It appears that I am may not be registering correctly with io-pkt. If I call ether_ifattach and manually add an
ARP entry for a given IP address I can send and receive packets without issue. However if I do not call ether_ifattach I
am unable to set or get an IP address.
02/20/2015 3:30 PM
post113363
using devc-pty.
You may be able to set up a ppp link between your host <-> target
and telnet / ftp over serial.
If I understand correctly you don't want arp. You're getting arp
because you're attaching as an ethernet driver. There's various
examples of non-ethernet interfaces but you'll probbaly have to go
through your sales rep.
