Re: usb wifi rtl8192cu driver
08/13/2012 10:23 AM
post94784
Hi all:
I've run into an icky issue with the porting of the netbsd wifi driver. The
code uses async usb tasks which I have absolutely no idea how to implement
in qnx. These tasks are also ordered in a task queue. Can anyone shed any
light on a possible approach? I am currently testing nw_pthread_create in
the attach but getting error 22...
Any advice would be much appreciated, thanks in advance.
B/R
Jim Tan
On Thu, May 10, 2012 at 9:30 PM, Jim Tan <shinjiuh@gmail.com> wrote:
> Hi everyone !
> I'm a newcomer to qnx 6.5.0. I have a USB wifi dongle (Zyxel NWD2205) that
> I need to setup an ad-hoc network with. Apparently, the chipset is realtek
> rtl8192cu, qnx doesn't have any driver support for this module. Netbsd does
> have the driver tho.
> http://cvsweb.netbsd.org/bsdweb.cgi/src/sys/dev/usb/?only_with_tag=MAIN
> (if_urtwn.c, if_urtwn_data.h, if_urtwnreg.h and if_urtwnvar.h)
> I also have the linux drivers from realtek site...
> What should I do at this point in time ? Can I simply download the 4 files
> from netbsd, create a qnx C project in momentics and make a devnp-urtwn.so
> target ? Or am I going about this in the wrong way? Is there a
> comprehensive guide that I can refer to about porting netbsd drivers ?
> Also, how should I make this driver available for other qnx users like
> myself ?
> Any help would be much appreciated, thanks.
> B/R
> Jim Tan
