Forum Topic - Problem with devn-tigon3.so:
I'm trying to get a PC (running QNX 6.3.2) on the network, using the PCI based Broadcom 5782 NIC. Here is the card
information as provided by "pci" command:
Class            = Network (Ethernet)
Vendor ID        = 14e4h, Broadcom Corporation
Device ID        = 1696h, NetXtreme BCM5782 Gigabit Ethernet
PCI Index        = 0h
PCI Mem Address  = fc500000h enabled
PCI Int Pin      = INT A
Interrupt Line   = 5
CPU Interrupt    = 5h
The network card works fine when booted using Linux & using tg3 (linux) driver. However, since the QNX system did not
automatically start a driver, I tried starting the trigon3 driver manually:
io-net -d tigon3 verbose -p tcpip
io-net -d tigon3 verbose=4 -p tcpip
io-net -d tigon3 verbose -p tcpip &
io-net -d tigon3 verbose=4 -p tcpip &
For each of the above commands, I observe the same behaviour - the ethernet card is not detected ("ifconfig" just shows
me the loopback device lo0, although "ps -eaf" shows io-net (with tigon3 driver) is still running). There is no output
on the console or in sloginfo about any anything related to devn-tigon3.so.
Please note that I did not build any new driver. I think io-net is automatically using the one available in /lib/dll.
Am I missing something here? Is my network card supported?
Rajat
Re: Problem with devn-tigon3.so
>  Broadcom 5782 NIC. Here is the card information as provided by "pci" command:
> PCI Index        = 0h
> PCI Int Pin      = INT A
> Interrupt Line   = 5
> CPU Interrupt    = 5h
> . However, since the QNX system did not automatically start a
driver, I tried
> card is not detected ("ifconfig" just shows me the loopback device lo0,
> is no output on the console or in sloginfo about any anything related to devn-
> tigon3.so.
> Thanks,
> Rajat
Try this, see if it works.
# slay -f io-net
# io-net -d tigon3 vid=0x14e4,did=0x1696 -p tcpip
make sure there is no space around the comma in vid/did option.
RE: Problem with devn-tigon3.so
----Original Message----
Sent: Friday, December 28, 2007 12:33 AM
To: drivers-networking
Subject: Re: Problem with devn-tigon3.so
>> Hi,
>>  PCI based Broadcom 5782 NIC. Here is the card information as
>> PCI Index        = 0h
>> PCI Int Pin      = INT A
>> Interrupt Line   = 5
>> CPU Interrupt    = 5h
>> (linux) driver . However, since the QNX system did not
automatically
>> ethernet card is not detected ("ifconfig" just shows me the loopback
>> still running). There is no output on the console or in sloginfo
>> about any anything related to devn- tigon3.so.
>> Thanks,
>> Rajat
> # slay -f io-net
Thanks, it worked.
Rajat
