Forum Topic - java memory size: (8 Items)
java memory size
on linux, how do you tweak the max memory size of the vm?
Cheers,
Colin
cburgess@qnx.com
Re: java memory size
-Xmx<size_in_mega>
> Cheers,
> Colin
Same as on windows -Xmx724M
Which would look like for IDE
eclipse/eclipse -vm /usr/lib/jvm/java-6-sun-1.6.0.06/jre/bin/java -vmargs -Xmx724M -XX:MaxPermSize=128m
(the other one another heap size for string objects which sometimes it is running out of)
> Cheers,
> Colin
is that an argument to 'qde'?
>> Cheers,
>> Colin
> http://community.qnx.com/sf/go/post32343
cburgess@qnx.com
Yes it is an argument to qde found in eclipse folder (after -vmargs), or you can put it in qde.ini.
If you talking about qde script which is in bin - you need to check if it passes arguments to actual binary.
>>> Cheers,
>>> Colin
>> General
Thanks, it appears to work.
>>>> Cheers,
>>>> Colin
>>> General
> http://community.qnx.com/sf/go/post32346
cburgess@qnx.com
Aha - but passing -Xmx1024M to qde is accepted - but ignored!
I had to change my system qde.ini to get it to work!
>>>> Cheers,
>>>> Colin
>>> General
cburgess@qnx.com
Command-line argument:
    -Xmx<size>
e.g., -Xmx1024M
If this is for an Eclipse-based product, the easiest way to specify this
is by appending this arg on a new line in the ini file (e.g., qde.ini or
eclipse.ini) following the -vmargs line.
HTH,
Christian
> Cheers,
> Colin
