Forum Topic - How to Hide the base window in a Photon application: (5 Items)
I am using QNX Momentics IDE version 6.3.2 and PhAB version 2.03. My problem is that on a button click on the base
window, I need to hide it and display a new window. I am using PhAB for developing my application. I tried using
PtContainerNullFocus but it didn't work. I also tried to set its resource, Pt_ARG_WINDOW_STATE as "Ph_WM_STATE_IS HIDDEN
" in a callback function attached to the button of base window but even that didn't work. Can someone please help me on
this?
RE: How to Hide the base window in a Photon application
have you tried...
   PhWindowEvent_t  we;
   memset( &we, 0, sizeof we );
   we.event_f     = Ph_WM_HIDE;
   we.rid         = PtWidgetRid(  ****YOUR_WINDOW_WIDGET_HERE****   );
   we.event_state = Ph_WM_EVSTATE_HIDE;
   PtForwardWindowEvent( &we );
- Thomas
> From: chandrashekhar kulkarni [mailto:community-noreply@qnx.com]
> Sent: 06 February 2009 13:16
> To: general-ide
> Subject: How to Hide the base window in a Photon application
> its resource, Pt_ARG_WINDOW_STATE as "Ph_WM_STATE_IS HIDDEN"
> but even that didn't work. Can someone please help me on this?
> http://community.qnx.com/sf/go/post21577
Re: How to Hide the base window in a Photon application
Hi Thomas,
Thanks for the help. I could hide my base window using the piece of code suggested by you but I am still not able to
display a new window in the similar way, within the same callback function. I tried it in the following way-
  PhWindowEvent_t  nwe;
  memset( &nwe, 0, sizeof nwe );
   nwe.event_f     = Ph_WM_FOCUS;
   nwe.rid         = PtWidgetRid(ABW_newwin);
   nwe.event_state = Ph_WM_EVSTATE_FOCUS;
   PtForwardWindowEvent( &nwe );
Can you further help me in figuring what is wrong?
the code below will merely give focus to a specific window, i.e.,
make it "active" in that all input will be directed to it.
To answer your question, I'd need to know whether the window you
want to show instead already exists (then we could just send it an
event), or need to be created first.
- Thomas
> Sent: 09 February 2009 08:48
> To: general-ide
> Subject: Re: How to Hide the base window in a Photon application
> Hi Thomas,
> http://community.qnx.com/sf/go/post21718
Re: RE: How to Hide the base window in a Photon application
  The window, 'newwin' is already created in PhAB which is linked to my base window within the same callback attached to
 a button on the 'base' window. I just need to display it hiding the later.
