Forum Topic - Setting Launch Configuration command line arguments: (5 Items)
Is there a setting or special string that will cause the launch configuration to prompt for command line arguments each
time it is launched?
Would be useful for programs that you wish to launch many times with different arguments each time.
- Dave Nickerson
Re: Setting Launch Configuration command line arguments
Implicitly it exists :-) If you launch application from Target File
System Navigator, it create invisible launch configuration and asks for
launch parameters to be passed to application. So it's easy to expand
this feature to the case of explicit launch configuration. But it is not
implemented yet. I think the correct way is to open CR in Przilla.
Alex
each time it is launched?
> Thanks,
> - Dave Nickerson
> http://community.qnx.com/sf/go/post19583
You duplicate configuration, change parameters and name and launch.
Should be finite number of parameter combination, you just end-up with
several launch configurations.
> Thanks,
> - Dave Nickerson
The IDE will prompt you for command line arguments during each launch of the executable by using ${string_prompt} as the
 C/C++ Program Arguments in the program's Launch Configuration.
- Dave
> configuration to prompt for command line arguments each time it is launched?
> > Thanks,
> > - Dave Nickerson
> > General
Something I did not know. Would be a next Tip of the Day.
the C/C++ Program Arguments in the program's Launch Configuration.
> - Dave
>>> Thanks,
>>> - Dave Nickerson
>>> General
> http://community.qnx.com/sf/go/post24496
