Forum Topic - java.lang.NullPointerException: (8 Items)
I am trying to debug an IPL and startup program using IDE 4.5 (6.4 M7 build).
I have an Abatron BDI3000 debugger connected to an i.mx27 development board.
Every time I try to launch the debug session, it appears to download the image, but then I get an error box with the
following.
"An internal error occurred during "Launching bsp-freescale-i.mx27",
java.lang.NullPointerException"
I have no idea what is causing this....
Any help would be greatly appreciated.
- Mike
Re: java.lang.NullPointerException
Does it have more stack trace followed by error? If not can you please copy it from the log? (Log available in workspace
/.metadata/.log) and post here?
Michael Cranston wrote:
> Hello,
following.
> Thanks,
> - Mike
> http://community.qnx.com/sf/go/post13509
Attachment: Text elaskavaia.vcf 116 bytes
Thanks for the reply, I figured there was a log somewhere, but I didn't know where to look.
Here is the log, it doesn't look very helpful to me.
!SESSION 2008-09-17 07:07:23.046 -----------------------------------------------
eclipse.buildId=I20080902
java.version=1.5.0_11
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Command-line arguments:  -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui.workbench 2 0 2008-09-17 07:07:37.343
!MESSAGE A handler conflict occurred.  This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2008-09-17 07:07:37.343
!MESSAGE Conflict for 'AUTOGEN:::org.eclipse.ui.cheatsheets.actionSet/org.eclipse.ui.cheatsheets.actions.
CheatSheetHelpMenuAction':
HandlerActivation(commandId=AUTOGEN:::org.eclipse.ui.cheatsheets.actionSet/org.eclipse.ui.cheatsheets.actions.
CheatSheetHelpMenuAction,
	handler=ActionDelegateHandlerProxy(null,org.eclipse.ui.cheatsheets.CheatSheetExtensionFactory:helpMenuAction),
	expression=AndExpression(ActionSetExpression(org.eclipse.ui.cheatsheets.actionSet,org.eclipse.ui.internal.
WorkbenchWindow@1818f80),WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@1818f80)),sourcePriority=
16640)
16640)
!ENTRY org.eclipse.ui.workbench 2 0 2008-09-17 07:07:37.546
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2008-09-17 07:07:37.546
!MESSAGE Conflict for 'com.qnx.tools.ide.qde.ui.shortcut.qconn.debug':
HandlerActivation(commandId=com.qnx.tools.ide.qde.ui.shortcut.qconn.debug,
	handler=org.eclipse.debug.internal.ui.launchConfigurations.LaunchShortcutExtension$LaunchCommandHandler@11dd95c,
	expression=,sourcePriority=0)
	handler=org.eclipse.debug.internal.ui.launchConfigurations.LaunchShortcutExtension$LaunchCommandHandler@a92aaa,
!MESSAGE Conflict for 'com.qnx.tools.ide.qde.ui.shortcut.qconn.run':
HandlerActivation(commandId=com.qnx.tools.ide.qde.ui.shortcut.qconn.run,
	handler=org.eclipse.debug.internal.ui.launchConfigurations.LaunchShortcutExtension$LaunchCommandHandler@1d07e4,
	handler=org.eclipse.debug.internal.ui.launchConfigurations.LaunchShortcutExtension$LaunchCommandHandler@1f13b08,
!ENTRY org.eclipse.core.jobs 4 2 2008-09-17 07:09:14.250
!MESSAGE An internal error occurred during: "Launching bsp-freescale-i.mx27".
!STACK 0
	at org.eclipse.cdt.debug.gdbjtag.core.GDBJtagLaunchConfigurationDelegate.launch(GDBJtagLaunchConfigurationDelegate.java
:67)
	at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:766)
	at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:608)
	at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:899)
	at org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlugin.java:1102)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
It should not have been failed but looks like you need to set binary path in the Main tab (which would be used for
source lookup)
16640)
16640)
> !STACK 0
java:67)
> 	at...
I wondered about that, but the instructions in the help are not really clear.
It says to place the .srec or .elf file to download onto the board in that field.
I am using an ARM processor and only the .srec format is available.  When I choose the same srec file I use in the the
debugger tab, I get the following error after download.
Error:
Program is not a recognized executable.
Thoughts?
There are two fields: one for image file (and this one does not check format) and another for symbol file.
Can you create an symbol file while building image (Doc should have instruction of how to do that). What are trying to
debug btw, startup?
Did you try to use cheat sheets (Help->Cheat Sheets)?
> Error:
> Thoughts?
> http://community.qnx.com/sf/go/post13559
RE: java.lang.NullPointerException
If you have created the symbol file (*.sym) for your binary, you can put
that symbol file path to the "C/C++ Application" field.
From: Michael Cranston [mailto:community-noreply@qnx.com]
Sent: Wednesday, September 17, 2008 9:58 AM
To: general-ide
Subject: Re: java.lang.NullPointerException
clear.
that field.
When I choose the same srec file I use in the the debugger tab, I get
Error:
Thoughts?
General
Re: RE: java.lang.NullPointerException
Thanks for the help.
I am trying to debug an IPL for the i.mx27 processor.  I am using the IPL from the i.mx21 processor as my starting point
 since they are similar parts.
It looks like I have to build an entire system image to be able to generate the srec format for the IPL and debug that.
I have not looked at the cheat sheets, just the help files.  I will give those a shot.
- Mike
