Forum Topic - App Profiler 2 - import of file.ptrace not working: (9 Items)
I tried to import a ptrace file after running the instrumented binary on a target.
This sesms not to be working, see the attached error message.
/hp
Attachment: Image error.JPG 10.76 KB
Re: App Profiler 2 - import of file.ptrace not working
There is a bug with race-condition. It never works or just sometimes?
> on a target.
> /hp
> http://community.qnx.com/sf/go/post7766
AW: App Profiler 2 - import of file.ptrace not working
it works never!
'til now - the ten times I've tried
>Von: Laskavaia, Elena
>Gesendet: Dienstag, 6. Mai 2008 21:59
>An: general-ide
>Betreff: Re: App Profiler 2 - import of file.ptrace not working
>instrumented binary
>> on a target.
>> /hp
>> General
>General
>http://community.qnx.com/sf/go/post7770
Geschaeftsfuehrung:  Dr. Wolfgang Ptacek  -  Michael Mauser  -  Regis Baudot
Sitz der Gesellschaft: Karlsbad - Registergericht: Mannheim HRB 361395
Re: AW: App Profiler 2 - import of file.ptrace not working
Can you send me an exception stack trace please? (In the log file
workspace/.metadata/.log)
> it works never!
AW: AW: App Profiler 2 - import of file.ptrace not working
here we go, see attached file
>Gesendet: Mittwoch, 7. Mai 2008 15:49
>An: general-ide
>Betreff: Re: AW: App Profiler 2 - import of file.ptrace not working
>> it works never!
>General
>http://community.qnx.com/sf/go/post7800
Attachment: Text .log 67.15 KB
Re: AW: AW: App Profiler 2 - import of file.ptrace not working
Oh, this is not race-condition, this is some installation problem... Was
is clear install or you update it?
Can you remove you configuration area (in windows is Documents and
Settings/<User>/momentics/4.5) and try again?
If it does not help you probably have to re-install it :(
> >An: general-ide
> >> it works never!
> >General
> Baudot
> Informationen. Wenn Sie nicht der richtige Adressat sind oder diese
> Absender und loeschen Sie diese Mail. Das unerlaubte Kopieren sowie
> you are not the intended recipient (or have received this e-mail in
> Any unauthorized copying, disclosure or distribution of the contents
> http://community.qnx.com/sf/go/post7803
AW: AW: AW: App Profiler 2 - import of file.ptrace not working
the installation was a "clean" one (just an unpack).
But this is  not the only version of momentics and eclipse I am using.
removing the configuration folder did not help I had to remove both,
the config folder and the workspace, after this it worked
I walked through the vmargs and found the
	-configuration configurationFileURL
I am now using this option, and it seems to do what I am expecting
It stores the config stuff in different folders so I could use my different installations without any more side effects.
thanks
hp
>Gesendet: Mittwoch, 7. Mai 2008 16:09
>An: general-ide
>Betreff: Re: AW: AW: App Profiler 2 - import of file.ptrace not working
>problem... Was is clear install or you update it?
>> >An: general-ide
>> >> it works never!
>> >General
>-  Regis
>> Baudot Sitz der Gesellschaft: Karlsbad - Registergericht:
>Mannheim HRB
>> 361395
>information. If
>> General
>General
>http://community.qnx.com/sf/go/post7809
Re: AW: AW: AW: App Profiler 2 - import of file.ptrace not workin g
You are using two 4.5 installation? It should create different configs
for 4.0.1 and 4.5 by default...
> thanks
> hp
AW: AW: AW: AW: App Profiler 2 - import of file.ptrace not workin g
yep, different 4.5 installations!
>Gesendet: Donnerstag, 8. Mai 2008 16:18
>An: general-ide
>Betreff: Re: AW: AW: AW: App Profiler 2 - import of
>configs for 4.0.1 and 4.5 by default...
>am using.
>>         -configuration configurationFileURL I am now using this
>> option, and it seems to do what I am expecting It stores the config
>> thanks
>> hp
>General
>http://community.qnx.com/sf/go/post7870
