Trackers
Trackers
Forum Topic - How to call an incremental build from the command line?: (9 Items)
I am using QNX 6.5 with bsp QorIQ-p1020-rdb, and I would like to perform incremental builds.  Is there a command line
option to do this?
~Best Regards, Carol
Re: How to call an incremental build from the command line?
Define incremental build?
It you use make from command line it is kind of incremental. Same from
IDE. You can enable (incremental) build on file save operation from
preferences.
On 07/03/2011 6:16 PM, Carol Wesolowski wrote:
> Hello,
option to do this?
> http://community.qnx.com/sf/go/post83802
RE: How to call an incremental build from the command line?
I want to build only what projects have changed not the entire workspace
in QNX.  We are using CruiseControl.net to run automated builds and
tests.  It is taking a long time for each QNX build because the entire
workspace and boot image is being built.
I tried adding the following command line argument to force only an
incremental build but this did not work.
C:\QNX650\host\win32\x86\usr\bin>mkbuild -ws
C:\KAS-Build\SVN\NightlyBuild\dev -
projects IOEngine -variant Release -targets Build
From: Elena Laskavaia [mailto:community-noreply@qnx.com]
Sent: Monday, March 07, 2011 3:38 PM
To: general-ide
Subject: Re: How to call an incremental build from the command line?
preferences.
> Hello,
perform incremental builds.  Is there a command line option to do this?
General
http://community.qnx.com/sf/go/post83803
Please be advised that this email may contain confidential
information.  If you are not the intended recipient, please notify us
by email by replying to the sender and delete this message.  The
sender disclaims that the content of this email constitutes an offer
to enter into, or the acceptance of, any agreement; provided that the
foregoing does not invalidate the binding effect of any digital or
other electronic reproduction of a manual signature that is included
in any attachment.
So you are saying if call this command two times in a row it does a full
re-build of a project each time?
> To: general-ide
> preferences.
>> Hello,
>> General
> in any attachment.
> http://community.qnx.com/sf/go/post83804
Yes.
Sent: Monday, March 07, 2011 4:54 PM
To: general-ide
workspace
> To: general-ide
> preferences.
>> Hello,
this?
>> General
> in any attachment.
General
http://community.qnx.com/sf/go/post83807
in any attachment.
If tools is broken - it is broken. You can try to use make directly.
Check this
http://community.qnx.com/sf/wiki/do/viewPage/projects.ide/wiki/IDEBuildFAQ
On 07/03/2011 7:58 PM, Carol Wesolowski wrote:
> Yes.
> To: general-ide
> workspace
>> -----Original Message-----
>> To: general-ide
>> preferences.
>>> Hello,
> this?
>>> General
>> General
>> in any attachment.
>> General
> in any attachment.
I do not understand what tools you are referring to.
Maybe I am not making myself clear.
I have a number of projects (see the following)
and I want to be able to recompile from the command line only the files
that have changed.  I can do this in the QNX IDE when I right click on a
project, if nothing has changed then it reports back that there is
nothing to build.
When I run mkbuild from the command line all of the projects are
rebuilt.  All of my projects are configured for CDT Builder.
Sent: Tuesday, March 08, 2011 6:54 PM
To: general-ide
Check this
AQ
> Yes.
> To: general-ide
full
> workspace
entire
>> To: general-ide
from
>> preferences.
>>> Hello,
> this?
>>> General
>> General
>> other electronic reproduction of a manual signature...
Attachment: Image image003.jpg 13.1 KB Image image004.jpg 12.25 KB
If you using managed build not makefiles not much you can do about it. Google cdt headless build.
> nothing to build.
> To: general-ide
> Check this
> AQ
>> Yes.
>> To: general-ide
> full
>> workspace
> entire
>>> To: general-ide
> from
>>> preferences.
>>>> Hello,
>> this?
Have you enabled "use parallel build" for the C projects? There's a known (and very annoying) bug that prevents
incremental build from working reliably of you do.
I reported this to QNX in november and they filed it as PR 81524. The three year old Eclipse CDT bug report is here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=217674
Apparently someone submitted a fix for the bug yesterday! I wonder if we may get a build of the IDE that includes the
fix relatively soon? The chances will probably increase if you contact support.
For system builder projects I don't think there is such a thing as an incremental build.
