Forum Topic - "CPU Usage" is reporting wrong threads: (5 Items)
The build 200712061800 has a problem in the "CPU Usage" reporting.
obviousley the reported threads are shifted by one.
So the CPU usage reported for Thread 3 is indeed the usage of Thread 2.
You see this in all CPU usage realted views as "Event Owner Stats" or the "Client/Server CPU stats"
RE: "CPU Usage" is reporting wrong threads
> From: Hans-Peter Reicher [mailto:hpreichert@harmanbecker.com]
> Sent: December 13, 2007 3:14 AM
> To: general-ide
> Subject: "CPU Usage" is reporting wrong threads
> Thread 2.
What version of the OS is the logfile you are looking at being
generated from?  There was a bug in the 6.3.2 release where the
thread name information was being emitted with the internal kernel
thread id, which meant that it was one off of the normal id.
This should only affect you if you are using thread names however.
Can you double check the Properties view for the log file you
are looking at and provide the information on the version of
the OS you are tracing.
 Thomas
> To: general-ide
> Thread 2.
Looks like I've found a potential problem.  Running some tests now and
the fix will be incorporated into the next integration build.
I'll still take that log file information if you get a chance to get
it however.
 Thomas
Re: RE: "CPU Usage" is reporting wrong threads
Hi Thomas,
here we go ...
SYS_RELEASE	6.3.2
SYS_VERSION	2007/08/08-12:49:15EDT
The SYS_VERSION does not show the PSPs that are included
our internal label tells me the this release is from CW37 - including the PSPs up to this.
If  your are interested in the kev .. I've put it to the ftp exchange into the folder fromHP
/hp
just tested the latest build 200801101800.
looks good
/hp
