Girisha SG
09/30/2010 3:30 AM
post69127
One more thing is when I run the executable for debugging I am getting the following error,(after pressing F5)
203^done,bkpt={number="1",type="breakpoint",disp="del",enabled="y",addr="0x00100de0",at="<main>",times="0"}
(gdb)
204-exec-continue
204^running
(gdb)
204*stopped,reason="exited",exit-code="01"
Elena Laskavaia
09/30/2010 8:52 AM
post69147
You need this library on target to work with memory analysis. Put it in the image or upload from
<installation>/target/qnx6/<architecture>/usr/lib/librcheck.so
On 30/09/10 03:15 AM, Girisha SG wrote:
> traces.rmat file on the target is empty however in the GDB promt of momentics IDE I am getting an error 'Cannot access
memory at address 0xe7c3c99c'. As I have mentioned earlier the source code in the momentics and ARM workbench are bit
different and hence it is not possible for me to step in into the code(I am getting the error 'No source file named
exampleAppMainMixer.c' in GDB prompt).
> Also I am getting error 'ldd:FATAL: Could not preload library librcheck.so' during run time.
> How can I resolve all these ?
> http://community.qnx.com/sf/go/post69125
