01/11/2012 4:43 PM
post90913
Hi Kendall,
you could use the PtWidget resource Pt_ARG_CURSOR_TYPE :
PtSetResource( widget, Pt_ARG_CURSOR_TYPE, Ph_CURSOR_LONG_WAIT, 0 );
...or define your own cursor bitmap and use that; see example snippet below.
Cheers,
Thomas
<snip>
struct bmpcursor_t {
PhCursorDef_t cdef;
char bmpbuf[ ( HEIGHT1 * BPL1 ) + ( HEIGHT2 * BPL2 ) - 1 ];
} bmpcursor;
char *bmp = bmpcursor.cdef.images;
/* Setup first layer description */
bmpcursor.cdef.size1.x = WIDTH1;
bmpcursor.cdef.size1.y = HEIGHT1;
bmpcursor.cdef.offset1.x = 0;
bmpcursor.cdef.offset1.y = 0;
bmpcursor.cdef.color1 = Pg_BLACK;
bmpcursor.cdef.bytesperline1 = BPL1;
/* Setup second layer description */
bmpcursor.cdef.size2.x = WIDTH2;
bmpcursor.cdef.size2.y = HEIGHT2;
bmpcursor.cdef.offset2.x = 1;
bmpcursor.cdef.offset2.y = 3;
bmpcursor.cdef.color2 = Pg_WHITE;
bmpcursor.cdef.bytesperline2 = BPL2;
/* Initialize first layer bitmap */
bmp[ 0] = bmp[14] = 0xfe;
bmp[ 1] = bmp[ 2] = bmp[12] = bmp[13] = 0x82;
bmp[ 3] = bmp[ 4] = bmp[10] = bmp[11] = 0x44;
bmp[ 5] = bmp[ 6] = bmp[ 8] = bmp[ 9] = 0x28;
bmp[ 7] = 0x10;
/* Initialize second layer bitmap */
bmp = &bmp[15];
bmp[ 0] = bmp[ 1] = bmp[ 9] = 0x70;
bmp[ 2] = bmp[ 3] = bmp[ 5] = bmp[ 6] = bmp[ 7] = bmp[ 8] = 0x20;
bmp[10] = 0xf8;
PtSetResource( widget, Pt_ARG_BITMAP_CURSOR, &bmpcursor, sizeof bmpcursor );
PtSetResource( widget, Pt_ARG_CURSOR_TYPE, Ph_CURSOR_BITMAP, 0 );
</snip>
From: Kendall Russell [mailto:community-noreply@qnx.com]
Sent: Mittwoch, 11. Januar 2012 20:48
To: photon-graphics
Subject: Mouse Cursor
I know that this has got to have a simple solution, but I have been unable to find it via google nor by searching the
QNX websites.
How do you change the mouse cursor to a wait cursor (hour glass) ?
Thank you,
Kendall
Photon microGUI
http://community.qnx.com/sf/go/post90910
